Look at the clearance between the needle and hook, making sure you push the hook away from the needle.
The shuttle can wear the spacer ring behind it and allow too much clearance so try cutting a thin cardboard ring to sit behind the spacer. I have seen this fix dozens of times on old 45k25's
  • 2 years later...
On 9/13/2018 at 10:13 AM, BaroqueLeatherGal said:
. I use 138 thread in the bobbin and 207 on the top, using a size #25 DYX3 LR needles of high quality.
There’s your problem! Way too much needle for that thread!
I hope he figured that out 2 1/3 years ago when this topic was last active. ;-)
Posted IMHO, by Wiz
Someone may be having the same problem... hahaha
