Members Danne Posted May 2, 2019 Members Report Posted May 2, 2019 8 hours ago, John11214 said: Question, how do you line them up after your pre-punch both side separatly which result in an "X". if you pre-punch them a little off your marking then it is ruined since it is two separately piece. Or that "X" doesn't have to match perfectly when glue together? Since my experience is limited to smaller test pieces, I can't really answer your questions. When I did my test pieces, I was very careful to start punch from the same corners. The biggest reason I don't punch from both sides is that then I have to make all parts to exact dimension before gluing. I feel like I have better control when I can trim pieces after glue. Quote
Members zuludog Posted May 2, 2019 Members Report Posted May 2, 2019 Have a look on YouTube for Nigel Armitage; he has started to do several videos on making pouches, and they are excellent. They show neat, precise working, including pre - pricking to get straight, even stitches. If you don't want to make pouches, the same techniques can be used for other items 'How to make pouches: 2 Round Flat' is simple and easy to follow, but they are all worth watching Quote
Rockoboy Posted May 4, 2019 Report Posted May 4, 2019 For something like a wallet or small pouch, I would cut and glue the pieces before punching (with a stitching chisel) the holes. That way, you will have your holes all lined up. Just be aware of the angle of the stitching chisel. It must be consistently vertical. If the pieces are too thick for the stitching chisel, I assemble a couple of the layers with glue, punch those holes, then assemble the next layer(s) with double sided tape, punch thru to mark the last layers, remove those layers and punch from the front so the holes are all exactly aligned. One idea I have not tried yet, but is on my horizon, after assembling all of the layers, use a 1mm drill bit in a drill press to get an accurate hole thru multiple layers. Then I can use an awl to enlarge the holes as required. Quote Kindest regards Brian "Whether you think you can or whether you think you can't, you are right" Henry Ford Machines: Singer 201p, Kennedy, Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
Members Danne Posted May 4, 2019 Members Report Posted May 4, 2019 (edited) 3 minutes ago, Rockoboy said: For something like a wallet or small pouch, I would cut and glue the pieces before punching (with a stitching chisel) the holes. That way, you will have your holes all lined up. Just be aware of the angle of the stitching chisel. It must be consistently vertical. If the pieces are too thick for the stitching chisel, I assemble a couple of the layers with glue, punch those holes, then assemble the next layer(s) with double sided tape, punch thru to mark the last layers, remove those layers and punch from the front so the holes are all exactly aligned. One idea I have not tried yet, but is on my horizon, after assembling all of the layers, use a 1mm drill bit in a drill press to get an accurate hole thru multiple layers. Then I can use an awl to enlarge the holes as required. The downside with this is if you skived your edges, you are going to have a hard time punching your holes straight. Using an awl takes a bit of practice but in my opinion, something you have to learn if you do wallets. At least if you do slimmer wallets. A lot of people seem scared of their awl. With a sharp awl and some practice, it isn't that hard. Edited May 4, 2019 by Danne Quote
Rockoboy Posted May 4, 2019 Report Posted May 4, 2019 7 minutes ago, Danne said: if you skived your edges I would usually skive or bevel my edges after assembly, stitching and cutting or sanding to final size and shape. Quote Kindest regards Brian "Whether you think you can or whether you think you can't, you are right" Henry Ford Machines: Singer 201p, Kennedy, Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
Members Danne Posted May 4, 2019 Members Report Posted May 4, 2019 1 minute ago, Rockoboy said: I would usually skive or bevel my edges after assembly, stitching and cutting or sanding to final size and shape. I don't think we are talking about the same thing here. Here is an example. The total thickness of leather layers is 3.5mm but the edges are around 2mm. So I'm talking about skiving all/most parts before assembling for a nice transition and a slim profile of the edges. Here I punch holes on the outer leather before assemble and go through with an awl. If I would use irons and go through the whole way, it would be very hard to do it straight. Quote
Rockoboy Posted May 4, 2019 Report Posted May 4, 2019 2 hours ago, Danne said: I don't think we are talking about the same thing here. You are correct. My mistake. I guessed incorrectly, that you mistook skiving for bevelling. If your edges once assembled are 2.0mm, you would be able to punch straight thru with a stitching chisel. If the chisel is held at a consistent angle (usually 90 degrees to the work surface), and aligned with a stitching line on the top face of the work piece, both back and front stitches can only be straight. Quote Kindest regards Brian "Whether you think you can or whether you think you can't, you are right" Henry Ford Machines: Singer 201p, Kennedy, Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
Members Danne Posted May 4, 2019 Members Report Posted May 4, 2019 19 minutes ago, Rockoboy said: You are correct. My mistake. I guessed incorrectly, that you mistook skiving for bevelling. If your edges once assembled are 2.0mm, you would be able to punch straight thru with a stitching chisel. If the chisel is held at a consistent angle (usually 90 degrees to the work surface), and aligned with a stitching line on the top face of the work piece, both back and front stitches can only be straight. If your edge looks something like this, you are going to have a hard time without an awl. Quote
Rockoboy Posted May 4, 2019 Report Posted May 4, 2019 I am definitely not an expert, but I don't believe you would skive from both sides as pictured, or if 2 or more layers were placed together, I don't see any job where this profile would be the result. I will refrain from making any further comment on this issue, because it appears I know significantly less than many others. Quote Kindest regards Brian "Whether you think you can or whether you think you can't, you are right" Henry Ford Machines: Singer 201p, Kennedy, Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
Members Danne Posted May 4, 2019 Members Report Posted May 4, 2019 (edited) 14 minutes ago, Rockoboy said: I am definitely not an expert, but I don't believe you would skive from both sides as pictured, or if 2 or more layers were placed together, I don't see any job where this profile would be the result. I will refrain from making any further comment on this issue, because it appears I know significantly less than many others. Yes, it would be possible to punch from the inside out on the wallet I showed earlier. Let's say the interior is orange and exterior black and I use orange thread, then I punch from outside. Also it's not uncommon you get the profile I showed you in my drawing. For example if you do a bifold with bill compartment and use softer leather outside. Here is an example. (Not mine it's from Chestermox) I'm not trying to be a wiseacre, just sharing my thoughts on this. Another common product where it's hard to punch through without awl is a card case with pockets on both sides. Edited May 4, 2019 by Danne Quote
