You've got a good eye, Don. When I looked closer the take-up spring looks a bit funny too and, strangely enough, most of the red paint marking oiling points appears to be intact. I suppose if you don't put oil down them then the paint won't be affected!
I would say that the needle plate screw isn't original and is just a countersunk screw with a slightly larger head. The other one appears to be slightly domed, whereas this one is flat. And there appears to be another knurled nut just behind the cross-threaded tension nut?
  • 3 years later...
On 10/24/2018 at 10:42 AM, Constabulary said:
Lots of rust, even on the hook and presser foot bar. Lots of unusual scratches behind the hook  - seems someone tried "something". Often the ZZ mechanism is gummed up on Pfaff 138´s and you need patients to free it (heat gun and oiling until it works again). 20 bucks if you like restoring machines and hunting for spare parts. Better look for a nicer one.
I know this is an old post - but I am now dealing with a gummed up ZZ mechanism.
If possible - would like to figure out a way to live chat (maybe with video) sometime.
Thank you!!!!!
Stephen
Moderator, Vintage Industrial Sewing Machines
