Members Szymon Posted November 22, 2018 Members Report Posted November 22, 2018 I have a sewing machine Adler 5-6, it is in quite good condition, but I would like to replace the presser foot, Feed dog and needle plate. If anyone knows where I can get these parts, please let me know. I would most gladly exchange for a flat plate, the one I now have at an angle, see the picture. Quote
Members Constabulary Posted November 22, 2018 Members Report Posted November 22, 2018 The 5-6 originally was set up for a roller presser foot. Not sure if some one probably altered the casting to make this needle plate fit. So If you don´t mind please post more pictures of the machine especially with removed needle plate. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Szymon Posted November 22, 2018 Author Members Report Posted November 22, 2018 (edited) 1 hour ago, Constabulary said: The 5-6 originally was set up for a roller presser foot. Not sure if some one probably altered the casting to make this needle plate fit. So If you don´t mind please post more pictures of the machine especially with removed needle plate. At the moment, I don’t have any photo with removed plate, I can do later. If it's like you said it was originally a roller, is it possible to change it to a foot presser , different plate and feed dog? Edited November 22, 2018 by Szymon Quote
Members jimi Posted November 22, 2018 Members Report Posted November 22, 2018 Could you measure the plate according to the picture? I don´t think you will find a flat plate for that machine?? It would have to be curved, and even curved ones are hard to find. Quote
Members Constabulary Posted November 22, 2018 Members Report Posted November 22, 2018 (edited) Since it is a fix presser foot bar as it seems (no moving back and forth) you can in stall a roller foot. The original roller foot slid directly onto the foot bar and a clamp held it in place so you could adjust is in angle and hight. "The modern" Chinese made roller foot mounts on the squared end of the presser foot bar just as the standard presser foot (in fixed position) BTW - DO NOT buy the roller foot for a Singer 31 they do not fit. You most likely can install needle plate and feed dog of a Singer 45K but feed dog may need a modification. Original Adler parts are VERY expensive. Or a cheap alternative - try GA5-1 parts which are dirt cheap on Ebay - the GA5-1 is based on the Singer 45K and the 45K shares parts with the Adler 5. https://www.ebay.com/itm/142866070102 This is just a fraction of what OEM parts cost and worth giving it a try, I think. I think the feed dog may need a little bit of modification but If I were you I would try it. Just a suggestion EDIT: to give you an idea of what original Adler parts would cost: https://www.ebay.de/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=adler+5%2C105&_sacat=0 Edited November 22, 2018 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Szymon Posted November 22, 2018 Author Members Report Posted November 22, 2018 3 hours ago, jimi said: Could you measure the plate according to the picture? I don´t think you will find a flat plate for that machine?? It would have to be curved, and even curved ones are hard to find. Sorry for late reply Quote
Members Szymon Posted November 22, 2018 Author Members Report Posted November 22, 2018 2 hours ago, Constabulary said: Since it is a fix presser foot bar as it seems (no moving back and forth) you can in stall a roller foot. The original roller foot slid directly onto the foot bar and a clamp held it in place so you could adjust is in angle and hight. "The modern" Chinese made roller foot mounts on the squared end of the presser foot bar just as the standard presser foot (in fixed position) BTW - DO NOT buy the roller foot for a Singer 31 they do not fit. You most likely can install needle plate and feed dog of a Singer 45K but feed dog may need a modification. Original Adler parts are VERY expensive. Or a cheap alternative - try GA5-1 parts which are dirt cheap on Ebay - the GA5-1 is based on the Singer 45K and the 45K shares parts with the Adler 5. https://www.ebay.com/itm/142866070102 This is just a fraction of what OEM parts cost and worth giving it a try, I think. I think the feed dog may need a little bit of modification but If I were you I would try it. Just a suggestion EDIT: to give you an idea of what original Adler parts would cost: https://www.ebay.de/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=adler+5%2C105&_sacat=0 Thank you very much for your help. I will try GA5-1, I thought about it before, these parts are not expensive. Quote
Members Szymon Posted November 22, 2018 Author Members Report Posted November 22, 2018 8 minutes ago, Szymon said: Sorry for late reply Quote
Members jimi Posted November 23, 2018 Members Report Posted November 23, 2018 5 hours ago, Szymon said: Sorry for late reply Yes the GA5-1 parts should fit, i have a plate here and measures almost exactly the same so i think it would work and they cant get any cheaper for a whole setup like that. The one you have on it is a copy of the singer 45k type they used for sewing shoe soles, and it looks like it might be a fixer upper foot?? Quote
Members Szymon Posted November 23, 2018 Author Members Report Posted November 23, 2018 Thanks m8, I just bought this. I hope it will fit Quote
