3 hours ago, MtlBiker said:
Wizcrafts... I'm confused about your reply.  1cm IS 10cm.  Are you saying that most upholstery class machines, maxing out at 10mm would not be able to sew 1cm?
No. I am saying that 3/8 inch is the maximum thickness they can sew. That is not supposed to be the constant thickness, just the occasional seam. If a project is 3/8 inch solid, it needs a different machine that can handle thick thread and has longer needles and stronger tension disks and a beefier take-up lever. It requires either a sole stitcher or a harness stitcher.
Posted IMHO, by Wiz
11 minutes ago, Wizcrafts said:
1cm IS 10cm
Oh???
Posted IMHO, by Wiz
2 hours ago, Wizcrafts said:
Oh???
Duh…. Typo… 1cm is 10mm.
Current machines: Janome HD3000 and Skyline S5, Consew 206RB-5, Singer Profinish serger, Techsew 2750 PRO, Sailrite LSZ-1 Premium, Consew DCS-S4 Skiver
Thanks for clarifying what you meant.  I really didn’t understand when you said a machine capable of sewing 10mm wouldn’t be a good choice for sewing 1cm.
LOL (I know that). Sorry, I couldn't resist!
Posted IMHO, by Wiz
13 hours ago, Wizcrafts said:
To sew 1cm you will need a different kind of sewing machine than a standard upholstery class walking foot. It will have to sew thicker than those machines are built to sew. Most upholstery class machines max out at 3/8 inch, with is 10mm
There are a few options you have to sew this thickness. But, first you have to decide on the geometry of the arm. How will you be sewing the parts together: from the outside edge or inside the slipper? It would really help if you post some photos of the slippers or shoes you want to make. Otherwise, we are just going to guess wildly about the type of machine you will need.
not sure if my last photo came through. This is what I sew through to attach the top to the sole. They aren’t hard soles, more of a soft upholstery leather but end up being a few layers.
thanks!
I can't tell how it needs to be sewn from the photo you posted. Can you please post another view of the shoe showing where the sewing has to be performed? Shoot at the lowest "resolution" and use a photo editor to reduce the file size if necessary.
If you have a wide enough lip around the bottom of the shoe it can be edge stitched then trimmed. The width of that lip and its thickness will help with the machine choices.
Posted IMHO, by Wiz
Here is a photo from the top view of the shoe inside where I sew around to attach it to the sole. I usually sew it with a 3/8” seam allowance and trim off the excess so the seam inside is not too much. I would love to be able to do them so no seam is felt on the inside but if I cut them down any more the fabric will possible come apart at the seam.
hope these help hit let me know if any more info is needed. I really appreciate your help. Thanks.
