I mostly make sheaths and sew with linen thread as I prefer that to synthetic
But I thought I'd make a couple of belts, and sew them with synthetic thread, which is stronger than linen
I was going to use Tandy's waxed nylon, then I saw some kevlar thread in my local Tandy store, reduced from £36 to £12 a roll, so I thought I'd try that. Now I have a couple of questions -
How can I secure the thread at the end of stitching? It doesn't melt and bead up when heated with a lighter flame. I've tied a knot in a sample length and that seems to work OK; do you think it will stay secured long - term without unravelling?
I've seen a video where they cut through a nylon cable tie with kevlar thread. I'm assuming they were able to do that as they used the thread in a sawing motion. If the belt end is sewn down securely and there's no movement I'm hoping that the thread won't cut the leather; any comments?
Thanks   Zuludog
I guess testing will be your best indicator of suitability, but I am thinking back-sewing 2 or 3 stitches might lock the end of the thread. I don't think glue will be helpful because (as far as I am aware) Kevlar is fairly slick and does not glue well.
Edited by Rockoboy
Kindest regards
Brian
"Whether you think you can or whether you think you can't, you are right"  Henry Ford
Machines: Singer 201p, Kennedy,  Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
Thanks; I was thinking of something like that.
So I'll finish it as I do for linen - backstitch  3 or 4 spaces then push the needles between the layers, tie it off, and do my best to hide the knot. I think the only way to find out what it's like is to just try it
There are some better knots for joining braid fishing line, which I believe is similar to kevlar. You might find some knots will slip, so I suggest you tie a couple and see if you can make them slip on a test piece before using them on a project.
Kindest regards
Brian
Beat ya to it!
I've tried the surgeon's knot on a short length of the thread already, and that is holding. Look it up on Google, it is basically a reef knot with an extra turn .
You can see I go backpacking; I've been using that on nylon guylines & cord  for years and it works well enough
Thanks for the advice though
Be careful with some of the stronger stuff, I used Spectrafiber for a bit and the beadstress that sold it to me said "if you try to tie this too tight you'll find fingers on the ground." I try not to imagine someone trying to snap off the excess by just yanking a thread that thin and strong. Like others have stated for finishing I just back stitch down a few holes and then used a curved needle to come between the plies, use a finishing knot and tuck it back in between the plies. Since it's backstitched down a few holes it receives virtually no tension and if it's tucked back in it receives no abrasion and is hidden from view.
Edited by CelticPrint
