Members snabbaville Posted February 21, 2019 Members Report Posted February 21, 2019 I'm thinking to change my clutchmotor to a servo motor.......is this a servomotor for my machine? JK-563A-1 220V 750W 1 HP SERVO MOTOR WITH NEEDLE POSITION Quote
Members dikman Posted February 21, 2019 Members Report Posted February 21, 2019 Should fit, modern servos use the common 3-bolt mounting used by clutch motors. Do you want a needle positioner? If not try and find one without it, should be cheaper. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members snabbaville Posted February 22, 2019 Author Members Report Posted February 22, 2019 What is needle positioner ? must i have that Quote
Members shoepatcher Posted February 22, 2019 Members Report Posted February 22, 2019 It allows you to have a needle up or needle down setting meaning when the stitch finishes, the needle is either left in the work or comes up out of the work. glenn Quote
