Does anyone have a tip for roundbraiding a curved gusset when the holes start to not line up?  I have tried going through a hole multiple times as I would do on a flat item around a corner but cant get it quite right.  Any tips greatly appreciated.  Thank you
This happens when I stitch a gusset, but is not so apparent as when braiding. You might have to do a little math and reconstruct the gusset so the holes on the curves are closer together.
Ugh, that would be some math.  I did notice my panel had 97 holes.  I made the gusset oversized to trim and had to add 3 holes to it.  Thank you I will mess with it some more.
