Dangerous Beans Posted April 19, 2019 Report Posted April 19, 2019 On 4/6/2019 at 2:56 PM, Japi said: When the Englishman first designed and started selling his burnisher, he did a deal with the people that helped developed it and they sold the burnisher and power source as a unit. Needless to say, it was all a con and the power source was a cheap generic brand , phase 1, two shaft machine that ran at 3000 rmp. Intended for a 150mm wheel power was 370W, Volts 230v- 50Hz and Amps 2. Having developed emphysema, I am no longer able to burnish anything much and nothing well I have used this machine with it's 2 1/4" outside diameter burnishing wheel since I got it, a little before I joined this site in 2016. I don't post much but I try to help. Take care and remember to have fun 3 Hello Japi, Normally, a quiet private message seems to resolve misunderstandings and that is how I like to deal with many issues. I do not like to air laundry in public. However, you appear to be levelling quite a severe accusation now out in the open so I think a more public approach may be prudent. I take it you are not happy with the motor, that is unfortunate, you have made contact with Just Wood to allow them to rectify any issues you may be suffering? I do not think you have emailed me asking for my input, I am suspecting not. You make mention of the power source being cheap and generic, yes, we thought it was good value too and Draper has a good name and is very affordable. You would have been well aware of this at point of purchase. As for it being single phase, I can't think of many leatherworkers that would want a burnisher running on three phase, this is the realm of constant industrial use. Those in that field are well aware of what they need and, I doubt many houses and small workshops have the ability to use three-phase machines. Onto the number of shafts, two is the most we can fit onto it so I cannot find issue there. As for the power, yes, 370W, perfect we thought, that is 1/2 a horsepower and will stop if trapped or the operator gets caught up in it with the 2amp causing it to overload and trip out preventing any serious harm. All this with enough power to get the job done. I am still not seeing evidence of this con you mention. You mention that it is "needless to say", yet you do, "it was all a con" are you referring to the deal I did? unlikely as you have no knowledge of any deal I have undertaken with Just Wood. You make no mention of the burnisher so I will surmise that you along with a great many others are happy with that, which leaves the motor. Just Wood clearly describe the motor and have an image showing the number of spindles, it leaves little room for confusion. If you bought it, you will have seen all of this so where has the confusion come from and how do you feel that you have been conned? everything you mention as a negative is clearly stated and transparent, I am at a loss Japi, are you able to help me understand your issue so I can help? In the meantime, I would be grateful if you could qualify your comment, retract it if said in error or evidence it if you stand by it. The Englishman Also called Nigel Quote The secret to creativity is knowing how to hide your sources. www.armitageleather.com
bermudahwin Posted April 19, 2019 Report Posted April 19, 2019 1 hour ago, Dangerous Beans said: In the meantime, I would be grateful if you could qualify your comment, retract it if said in error or evidence it if you stand by it. Well said, sir. Harry Quote No longer following it.
