Members Secondgunman Posted April 20, 2019 Members Report Posted April 20, 2019 Happy easter weekend all. I was wondering if anyone could help with the choice polyester vs nylon cord in this machine. Can i get them pre lubed? Do they need to be lubed? Am I putting to much thought into this? Cambell Recommended polyester because they said nylon stretches a bit. Then on the flip side of the coin a local leather veteran said use the nylon no need for lube. But that being said he runs an Equally old but slightly different Landis machine. Any recommendation would be greatly appreciated someone with Hand on cambell Experience would be exceptional. Thanks for your time. Quote
Moderator Wizcrafts Posted April 21, 2019 Moderator Report Posted April 21, 2019 Campbell Randall Lockstitch machines were designed before there was any synthetic thread. The standard thread for these machines is left twist glazed linen thread. The best is Barbour's Irish Linen Thread, which is sold by Campbell Randall. It works very well when run through Campbell's Lax-Wax in the lube pot. It can also be run through Sellari's liquid stitching wax. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Secondgunman Posted April 21, 2019 Author Members Report Posted April 21, 2019 Thanks for the response Quote
Moderator Wizcrafts Posted April 22, 2019 Moderator Report Posted April 22, 2019 If you don't want to use linen thread and wax, use the lubricated bonded polyester thread that is sold by Campbell Randall. You will have to use a slightly bigger awl than if you used linen thread, which bends easier and forms tighter 'knots.' Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
