Members HCLW Posted April 29, 2019 Members Report Posted April 29, 2019 (edited) I have an 111 153 that sews pretty good until you do a u turn to lock the stitches down. The bottom thread leaves a loop. The bobbin tension is at max. The knot is perfectly centered. I’m turning it just when the needle starts back up. Any advice? Edited April 29, 2019 by HCLW More information Quote
Members DavidMillsSaddlery Posted April 29, 2019 Members Report Posted April 29, 2019 You’re spinning the work at the most crucial time when the hook is to pick up the loop! You need to spin it before the needle starts coming back up! Quote
Members HCLW Posted April 29, 2019 Author Members Report Posted April 29, 2019 47 minutes ago, turbotexas said: You’re spinning the work at the most crucial time when the hook is to pick up the loop! You need to spin it before the needle starts coming back up! I think I’ve tried that but I’ll try again. thanks Quote
Members DavidMillsSaddlery Posted April 29, 2019 Members Report Posted April 29, 2019 19 minutes ago, HCLW said: I think I’ve tried that but I’ll try again. thanks On the downstroke Quote
Members HCLW Posted May 9, 2019 Author Members Report Posted May 9, 2019 Turning just before bottoming out helped a little. Tightened bobbin thread helped just a little more but still leaves a loop. Turning a corner is usually ok but turning around to lock the stitches leaves at least a small loop half the time. Could it be a timing issue? I’ve checked the timing as best I know how and it seems ok to me. I have a cobra class 26 and all instructions I’ve seen says to turn your piece immediately after the needle starts up... confusing. Quote
garypl Posted May 9, 2019 Report Posted May 9, 2019 I have three machines and I always turn the piece around after the needle has risen about 1/4” so I am certain the hook has caught the loop. Never have problems with loop at bottom, but maybe I am just lucky! Gary Quote
Members DavidMillsSaddlery Posted May 9, 2019 Members Report Posted May 9, 2019 29 minutes ago, garypl said: I have three machines and I always turn the piece around after the needle has risen about 1/4” so I am certain the hook has caught the loop. Never have problems with loop at bottom, but maybe I am just lucky! Gary Yes, that’s what needs to be done! 1 hour ago, HCLW said: Turning just before bottoming out helped a little. You need to turn AFTER bottoming out, that way the shuttle has already picked up the thread! When you turn prematurely the thread gets “twisted” and is no longer in the proper position for the shuttle hook to pick it up! Quote
