Skiving without a skiving knife? And Splitting with minimal tools?
  • CFM
a 1" wood chisel will work , or you can sharpen up a good quality putty knife such as this if you have a belt sander and with belts up to 1000 grit, then go to a arkansaw stone or 2500 grit sand paper, then polishing compound on a strop. I,ve even used my belt sander to skive once in a while.
  • 2 months later...
I've always thought of doing this... do you have any problems with regards to the thickness of the blade?
  • CFM
this particular brand, as well as others, has two thickness blades one very thin flexable and one heavy/thicker and much more stiff get one with the heavy blade that doesn't flex.
okay... will try and find the thickest one I could find
  • CFM
it should get you by, realize its not very high carbon steel.and will need to be sharpened more often
