Members SilverForgeStudio Posted April 30, 2019 Members Report Posted April 30, 2019 I have searched the archive and potentially am not hitting on the right combination of word or the right wording/phrase- so if this has been covered please let me know and what the proper keywords are and Ill go digging. Trying to find out if I use brass or copper rod for rivets how to protect the leather from growing a verdigris/tarnish ring from forming. Figured I would be able to paint the head and shank of the rivet with a bit of clear lacquer or nail polish- or even a disc of light plastic under the head like a washer to isolate the contact? I have a few ideas I am trying and know I do not need to re-invent the wheel- but I have several pieces I tossed in a box and they all have whitish and green halos around them. And yes it is partly from non use/oiling/polishing or handling... So Im hoping to avoid it on future projects or at least mitigate it in the meantime! Quote
mikesc Posted April 30, 2019 Report Posted April 30, 2019 Short term solution...nail varnish ( which is low grade acrylic lacquer ) ..chips very easily..and is not truly glossy ..because it is hygroscopic. Long term solution.. 2 part ( 2 pack ) polyester or epoxy "clear" as used in "clear coats" for high grade metallic car paints..includes catalytic hardeners, cyanoacrylates* ( polyisocyanates ) usually..must use a mask ( against toxic vapours ) ..good to stay glossy for around 10 years .. *Miss-use of them can kill you..overdose is odourless ..by the time you smell it, it is frequently too late..even the best masks give no warning when they are saturated and no longer filtering the toxins..and they are long term carcinogenic.. I came close to not waking up again twice when I was a custom painter using these..so i quit.. Quote "Don't you know that women are the only works of Art" .. ( Don Henley and "some French painter in a field" )
Contributing Member fredk Posted April 30, 2019 Contributing Member Report Posted April 30, 2019 Rustins makes a metal lacquer which is robust and long lasting and is inexpensive. Quote Al speling misteaks aer all mi own werk..
Members SilverForgeStudio Posted April 30, 2019 Author Members Report Posted April 30, 2019 Thanks Mike and Fred! I dont think I will be using anything that volatile Mike! Sounds harsh- glad you are still among the living for it... sage advice. Fred I think Im on the right track with the lacquer route so thanks for confirming it- I appreciate the input folks- pics when the project is done! Quote
Contributing Member fredk Posted April 30, 2019 Contributing Member Report Posted April 30, 2019 linky; https://www.rustins.ltd/rustins/our-products/renovators-for-metal/ metal-laquer Rustins is designed for lacquering brass door furniture so it does last. I used to use it as a barrier between metals and metals-materials Quote Al speling misteaks aer all mi own werk..
mikesc Posted April 30, 2019 Report Posted April 30, 2019 (edited) Yep, I think Fred's idea is safer ( you can't get it here though, unless ordered "online" ) ..nickel plated rivets ( or even gold plated rivets if you are going "luxury" ) is another option, I presume you'd know how to electro plate your own ..Just don't breath the chemicals or the vapours given off either :) Edited to add.. Possibly a drop of clear epoxy , the kind sold for "incrustations/ inclusions" might work, epoxy should "hold on" to polished metal OK ( "ish" , test it ) and may not discolour ( again test it to see )..Polyester resin would no be clear enough, but some epoxies might be ? Edited April 30, 2019 by mikesc Quote "Don't you know that women are the only works of Art" .. ( Don Henley and "some French painter in a field" )
Members SilverForgeStudio Posted May 2, 2019 Author Members Report Posted May 2, 2019 Thanks Fred and Mike- Ive gotten a small tin of "Brass Lac" from the overpriced art store/hobby shop near me- Ill give it a swing and see what happens! Quote
Members z33 Posted September 30, 2019 Members Report Posted September 30, 2019 I am new and have been reading a lot on brass and leather and pH and verdigris. I make leather belts, and while brass and brown leather look beautiful, I feel time will not be kind. I have already make the mistake of using neatsfoot oil on my leather. I am now given to understand that neatsfoot is acidic, and so I theorize it may promote corrosion of brass? I do not know. I have read about benzotriazole, which is soluble in alcohol and warm water. I am wondering if micro spot treating just around the brass where it touches the leather is a good idea. I have also read about L-cysteine in PEG400 which is used to preserve wood/brass. I am wondering if n-acetyl-cysteine dissolved in water could be used to micro-treat the leather-brass interface; the water will dry, leaving the cysteine behind. I have no clue if it will be effective. I am also wondering if a borax solution can similarly be used very carefully; leather has a usual pH of 3 to 5 and borax is alkaline and can dry out leather - but would minute quantities just at the metal-leather interface protect the brass? Quote
Contributing Member fredk Posted September 30, 2019 Contributing Member Report Posted September 30, 2019 I reckon you are over worried. The ancients never worried about such thinks and in the UK leather items with brass items attached from up to 2000 years and more ago have been found. The brass is not corroded where it is attached to leather and if the leather is intact and still existant it shows no reaction to the brass item. Are you wanting your items to last 2 millennia or more? I think there is a lot of odd information flowing about on the internet. A lot of it is urban-myth. The people propagating this information have never actually experienced what they claim. I've used brass buckles and loops and rivets with both veg tan and chrome tan leathers for over 20 years and never once have I seen any of these reactions which are claimed by internet worryors Quote Al speling misteaks aer all mi own werk..
mikesc Posted September 30, 2019 Report Posted September 30, 2019 (edited) Benzotriazole, is going to be better than either n-acetyl-cysteine or borax... if you have it to hand. Although they will all work..( as antioxidants ) in descending order of efficacy.. Benzotriazole , n-acetyl-cysteine*, Borax** .. However it, Benzotriazole does have some antiestrogenic properties, so on belts, yes.. But not on things that would be in long term skin contact such as watch straps , bracelets etc. *n-acetyl-cysteine binds very well to proteins, such as the collagen in leather..but some people may show allergic symptoms on contact with items treated, fewer than the small percentage of those who show allergic symptoms after inhalation or ingestion, but..someone might decide to sue.. Various research and information about the collagen in leather can be found by searching that phrase "collagen in leather" ..without the quotes. **Borax acts as a "pH buffer"..would have been better to apply it prior to posing the brass ware..and it may show up as micro crystals on the surface where it is applied after a time. HTH :) 3 to 5 is quite a large range ( before neatsfoot oil..and neatsfoot oil covers "a multitude of sins" )..find out ( as far as possible ) which final pH which you are dealing with, before attempting to deal with it, and it's potential*** reaction with your metal ware. ***unavoidable ( well I could have, but decided not to ) pun ;) Edited September 30, 2019 by mikesc Quote "Don't you know that women are the only works of Art" .. ( Don Henley and "some French painter in a field" )
Members robs456 Posted September 30, 2019 Members Report Posted September 30, 2019 49 minutes ago, z33 said: benzotriazole L-cysteine in PEG400 n-acetyl-cysteine micro-treat leather-brass interface Isn't that the recipe for Rock? I also make belts, mostly in this way: Get brass buckle Cut leather strap Skive buckle end Punch buckle tongue slot fold leather around buckle Sew wear for a hundred years or more. Don't overthink stuff too much. Quote Instagram: rob5leather
mikesc Posted September 30, 2019 Report Posted September 30, 2019 "Isn't that the recipe for Rock?" Good thing you are not cooking.. ;) However.. "Don't overthink stuff too much." Is true.. :) Quote "Don't you know that women are the only works of Art" .. ( Don Henley and "some French painter in a field" )
Members Dwight Posted September 30, 2019 Members Report Posted September 30, 2019 On 4/30/2019 at 1:52 PM, SilverForgeStudio said: I have searched the archive and potentially am not hitting on the right combination of word or the right wording/phrase- so if this has been covered please let me know and what the proper keywords are and Ill go digging. Trying to find out if I use brass or copper rod for rivets how to protect the leather from growing a verdigris/tarnish ring from forming. Figured I would be able to paint the head and shank of the rivet with a bit of clear lacquer or nail polish- or even a disc of light plastic under the head like a washer to isolate the contact? I have a few ideas I am trying and know I do not need to re-invent the wheel- but I have several pieces I tossed in a box and they all have whitish and green halos around them. And yes it is partly from non use/oiling/polishing or handling... So Im hoping to avoid it on future projects or at least mitigate it in the meantime! Absolutely NOTHING you will do will STOP leather from attacking any metal it comes into contact with, . . . with the exception of Gold. All others will at one degree or another be attacked by the chemicals used in the tanning processes. Copper is at the top of the list for getting funky fast, . . . iron right behind it, . . . then steel and then brass and aluminum. You can mitigate it to a certain degree with various coatings, . . . but just remember that you are not going to STOP it altogether. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members SilverForgeStudio Posted September 30, 2019 Author Members Report Posted September 30, 2019 (edited) 4 hours ago, fredk said: I reckon you are over worried. Are you wanting your items to last 2 millennia or more? I think there is a lot of odd information flowing about on the internet. A lot of it is urban-myth. The people propagating this information have never actually experienced what they claim. I've used brass buckles and loops and rivets with both veg tan and chrome tan leathers for over 20 years and never once have I seen any of these reactions which are claimed by internet worryors Fred- I have made a couple of items and I do not think it is necessarily the "Ancients " metallurgy- one item I can attribute to being in a salty environment as the cause of the green ring around the rivets. The other- I am at a puzzle about. Probably sweat- but nonetheless I am suspect the "Quality" of metals items today is more suspect than the leather. And why not last 2k years! That would be awesome! I too have items out there for a bit with no visible green ringing- but I am trying to improve and my process in order to move items from a hobby into a craft- potentially Bronze may be the answer I am seeking- Aluminum Bronze is fairly easy to cobble-up in the shop and has a high resistance to corrosion. On my daily wear the brass is not showing any sign of verdigris- but as I said previous- only 2 or three items have been notably stained. And they are used in marine environments or in a physical environment with sweat. 1 hour ago, Dwight said: Absolutely NOTHING you will do will STOP leather from attacking any metal it comes into contact with, . . . with the exception of Gold. All others will at one degree or another be attacked by the chemicals used in the tanning processes. Copper is at the top of the list for getting funky fast, . . . iron right behind it, . . . then steel and then brass and aluminum. You can mitigate it to a certain degree with various coatings, . . . but just remember that you are not going to STOP it altogether. Understood- and I appreciate the reply! I am working with a lacquer UNDER the rivet to see how they fare (will not know until after hunting season is over) and I am as well looking into Bronze as it is a bit higher in the corrosive resistance alloys (Aluminum bronze or "Red" bronze). I appreciate all the thoughts and replys! And Fred- I respect your opinion- not trying to anger the ancients... bad ju-ju there! HA! Seriously- thanks! Edited September 30, 2019 by SilverForgeStudio Quote
Members jrny4wrd Posted February 16, 2024 Members Report Posted February 16, 2024 Maybe a thin rubber washer. Quote
Members TonyV Posted February 17, 2024 Members Report Posted February 17, 2024 I don't worry about it. The copper rivets I use won't get enough verdi gris to worry about. With handling and use, the minor amounts of corrosion gets brushed off. The only time that I have seen big amounts of corrosion on metallic trim on leather is when an article was left wet in a close up container for an extended time. Not to mention; when I topcoat my projects, the rivets and snaps get a coat of the finish. And ain't veg tan leather tanned with tannic acid ? Quote
