I have a new to me Adler 267-373, and let me preface this question with the fact that I know next to nothing about sewing machines.) I’ve looked at numerous diagrams and pictures online and I’m fairly confident that I have the machine threaded right. I cannot seem to get my stitch knot to sink into the leather. I have a very minor grasp as to how to adjust tension, but have not seen any change in the stitches when I do make adjustments. Also, when making these adjustments, my thread wants to get jammed up and then throws my timing off, forcing me to constantly reset it. It says my pictuare too large to upload but I’ll keep playing with that.
If we make the assumption that the machine is properly threaded, the tension problem could simply be too small of a needle for the thread combinations. Consult this needle and thread chart and use the largest needle recommendations in dense leather.
Posted IMHO, by Wiz
Thank you I am using the largest one the machine can take. I think it is an adjustment issue.
I found the needle size is a big part of the tension adjustment, what size needles do you have?
I’m using these ones (140) with 138 thread. It’s supposed to handle between 120-140 but it wouldn’t sew at all with the 130s in.
Edited by 07milch
I have better success using #23 (160) needles with #138 thread.
Posted IMHO, by Wiz
Ok! There was a chart somewhere, can’t find it at the moment, that said this machine could only use 120-140 needles. I’ll see if I can find a 160 and try that.
  • 2 weeks later...
I got the 160 needle in but unfortunately it made no difference. Still hunting for the solution.
