Members Roz0323 Posted June 5, 2019 Members Report Posted June 5, 2019 Hello everyone. Let me start by saying that I am with no question a GREEN HORN. just about finished with a umarex glock 19 holster. It is my first holster and my first wet molding project. there are ton of flaws and things that i will change moving forward but all in all it seems to function great. snug fit, locks into place and the 7 oz is rock hard. I have some questions about the edges. i originally beveled the edges but then after stitching i ended up sanding them in order to even everything out. (the pics are prior to sanding) Now the edges are a little square. I would like to use a red edge paint. is my next step to apply paint then sand and reapply more paint? In between do I use canvas? After the coats are applied, do i still seal the edge paint with beeswax and burnish? There are so many options so i am trying to get a formula broken down to layman’s terms. side question!- would obenaufs soften the leather too much as an exterior finish? Thank you for the assistance. Quote
Members Mattsbagger Posted June 6, 2019 Members Report Posted June 6, 2019 There are quite a few videos on YouTube that show how people do edge paint. Also if you haven’t tried it yet use the search function on this site and it should bring up a bunch of posts on edge paint. Don’t burnish smooth before you paint though the leather needs a “tooth” for the paint to grip to. Quote
garypl Posted June 6, 2019 Report Posted June 6, 2019 I use Giardini edge paints and they are the most durable I have found. I sand edges smooth, apply a base coat of Giardini Base Coat, then start painting with the edge paint, sanding between coats to remove any wrinkles. Once it is finished, I sometimes put a coat of wax on it, but really doesn’t require any additional burnishing or finishing once you are happy with the finish. Gary Quote Cowboy 4500, Consew 206RB-4
Members MisterSmith Posted June 12, 2019 Members Report Posted June 12, 2019 I use Uinter’s edge paint and primer from rmleathersupply.com. My process for veg tan is as follows: 1) sand and even up the edges w/ 150 grit sanding belt 2) bevel edges and apply 1 coat of Uinter’s primer and let dry for 20 min 3) apply 1st coat of edge paint and let dry for 20-30 min 4) buff knock down uneven spots with 500 grit sand paper (can be found @ Walmart or any auto parts store’s paint and detailing section) 5) apply second coat of edge paint After this you can leave it as is or apply 80/20 beeswax/paraffin on the edges and burnish with a waxed canvas cloth. Happy Leather crafting! Stick with it, the name of the game is trial and error so do what brings YOU the best results. Quote
Members Roz0323 Posted June 12, 2019 Author Members Report Posted June 12, 2019 Thank you for the detailed instructions. I will absolutely use your method. Quote
