Hello, I'm from Argentina and a friend who is with a pole boots entrepreneurship I consult if there is a sewing machine that works parallel to the sewing arm. What he found is the following machine:
https://www.youtube.com/watch?v=KInflV0HEdI
<iframe width="560" height="315" src="https://www.youtube.com/embed/KInflV0HEdI" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
I told him that the closest thing to that economical is a Singer 29K but I would like to know if there is any other option with that style of sewing.
I apologize for my English!
  • Replies 29
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
That style of feed is called transverse feed, or sew up the arm. There are sew up the arm machines used to make blue jeans, but they aren't really able to sew with heavy thread and may only be chainstitch machines.
There are some specialty sew up the arm machines that are smaller than the Hightex in the video, but you'd have to search the Internet for them.
If a chainstitch is acceptable, there is a brand made in the USA called Puritan. Their machines are chainstitch with needle and awl feed. The make an up the arm machine called The Alligator.
Posted IMHO, by Wiz
Thank you! The problem I have is that I am in Argentina, I am currently preparing an Adler 70/30 in very good condition. The same person who is repairing the Adler told me that there were some old Singer that could sew like the Alligator.
He happened to me the photo of the black Singer but he says that he sews along the arm, I do not know if it will be true ...
The machine in the last two photos isn't going to "sew along the arm", because the feed dogs ( zoom in to see them ) are pulling from front to back..
HTH :)
It looks to be a very long arm machine, maybe for sewing sails.
Edited by mikesc
"Don't you know that women are the only works of Art" .. ( Don Henley and "some French painter in a field" )
From what I can see in the dark photos, that cylinder arm machine just has normal feed over the arm. Transverse feed machines have the foot/feet and feed dog aligned inline with the arm, not across it. Singer used to make a machine that sewed up the arm.
Posted IMHO, by Wiz
You might be able to get the Adler to do this , if you rigged up some sort of straight edge line guide* on the arm so that as you sewed along the arm you could watch the stitched seam that you were sewing stayed aligned with it, and thus make sure it did not wander.
*Something that went around the upper arm and held a block with a hole bore vertically so that it allowed a vertical bar with a straight edge to be lowered so as to rest parallel to the lower arm on the material along the seam as you were sewing.
Two large "hose clips" or strong cable ties to hold a bar with a vertical hole and a side hole to allow a threaded guide stop screw..that would let the bar slide up and down..then on the bottom end you attach a small bar about 50mm to 100mm long that rests on top of what you are sewing , right up against your stitch line..and parallel to the lower arm..if you watched that your stitches stayed "along it" that would keep your seam " along the arm" pretty straight..Not perfect..but it might do until you can get a true along the arm machine.
If you go to this Singer model number page and look under the section for the 11 series, there are several listed as up the arm feed machines. Finding one in working condition is another matter. They are from the 1940s and WWII.
Edited by Wizcrafts
Added the link I forgot earlier
Posted IMHO, by Wiz
Umm, Wiz..you forgot to post the link to "the page" ..."If you go to this Singer model number page and look under the section for the 11 series" mentioned in your last post.. :)
Thank you :)
