Members kodadd Posted June 18, 2019 Members Report Posted June 18, 2019 (edited) IMG_7219.HEICIMG_2155.HEIC Picked this up yesterday it has a 3 ph 220 motor so need to swap that out, down loaded the manual, questions what do I need to buy any other accessories more feet? question I need a new servo motor that's 110v any suggestions where I should get one and what to do with the old 220 3 ph motor? it works great would someone want it? Edited June 18, 2019 by kodadd pics didn't post Quote
mikesc Posted June 19, 2019 Report Posted June 19, 2019 (edited) I "converted" your .heic image to .jpeg.. .heic is a new format..used at the moment mainly by Apple on iphones..most browsers, and many websites, cannot use it at the moment..If you want to post .heic, it is necessary to convert it to .jpeg before uploading the image(s) Edited June 19, 2019 by mikesc typo Quote "Don't you know that women are the only works of Art" .. ( Don Henley and "some French painter in a field" )
Members kodadd Posted June 19, 2019 Author Members Report Posted June 19, 2019 Thanks I noticed the heic and wasn’t familiar with it. I appreciate the heads up. Now any help converting this thing from pneumatic reverse back to the mechanical or should I hook a compressor to it and go with it? Quote
mikesc Posted June 19, 2019 Report Posted June 19, 2019 Someone who has one with ( or which had "air reverse" ) would know better than I..I'd guess ( and it really is a guess ) that you ought to be able to remove the air system and use it as "push down on the reverse lever bar at the front of the machine for reverse" fairly easy..But..we can't see the back of the machine, to see what the "air reverse" system entails.. Pics of the back of the machine, and of the back of "under the table" would help.. Air systems are noisy ( as are the compressors, unless you spend a great deal of money for a silent one big enough to run that )..and are only normally used in high volume fast sewing situations..like factories. Quote "Don't you know that women are the only works of Art" .. ( Don Henley and "some French painter in a field" )
Members DrmCa Posted June 19, 2019 Members Report Posted June 19, 2019 If your old 220V motor is a clutch motor, it is boat anchor. You could get a few bucks for it at a scrap yard, or wait for years on Craigs list for anyone to buy it for 20-40 bucks. But if it is a servo, get an inverter and stick to it, as it would be miles ahead of any 110V servo. I guess it should be a servo motor as you have a pneumatic cylinder sticking out from the back of the machine. Quote Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
