Members shoepatcher Posted November 18, 2023 Members Report Posted November 18, 2023 Clickers have a very solid base. You can lift them with a fork lift. You have to get it up enough to put 4x4 under them. A pallet jack will also lift it up enough to get 4 x 4 under it. Then bolt the (2) 4 x 4's to the clicker. I have moved clickers before. If moving and transporting them some place, drain the gallons of oil out of the machine first. You move it and oil will spill which is a mess. I use the the pallet jack to lift the machine, put blocks of wood under not blocking the bolt holes. Cut 4x4 to go front to back. Drill 4x4 for bolt holes, recess bottom of hole and bolt to machine with dead recess in the bottom. Bolts are upside down. Lift up machine with pallet jack and remove blocking. Lower machine on to the floor with it resting on the 4x4's. Now can be moved with either pallet jack or forklift. glenn Quote
