Contributing Member Tim Schroeder Posted September 2, 2019 Contributing Member Report Posted September 2, 2019 Just curious if anybody is building RFID wallets. Do you need to line every pocket or do you just need a layer in between the outside cover and the lining on the outside so when you fold it there would be a layer on both sides of the cards. I know the RFID material can't be in contact with the cards or it will become an antenna. Thanks for any input. Quote
Contributing Member fredk Posted September 2, 2019 Contributing Member Report Posted September 2, 2019 A. I put it just on the outside layer with a thin cloth liner glued over it, which also gets sewn at the edges b. don't bother with the fancy expensive RFID stuff. Aluminium tape used for insulating heating pipes is cheaper. £4.99 for a 50m roll. Its also thicker by a smidgen and self adhesive. It works fine & dandy Quote Al speling misteaks aer all mi own werk..
Contributing Member Tim Schroeder Posted September 2, 2019 Author Contributing Member Report Posted September 2, 2019 Thanks Fred I already have some of the copper stuff. Thanks for the tip on the aluminum tape. Quote
