Cheval
Tape/webbing foot assistance
Hello all-
Does anyone have an idea of where to find a foot set like the one pictured below? I am doing a similar operation of applying tape/webbing on top of material.
Thanks,
C
What machine do you have?
The one in the picture seems to be a Pfaff double needle walking foot machine with tape guide.
What you are looking for is called GAUGE SET and depends on your type of machine and tape width / needle distance
Maybe these folks have what yuo need:
http://www.khsew.com/index.php?route=product/category&path=208_209
Edited by Constabulary
I have a Consew 745R30 and a 1" gauge set. I have a somewhat custom inner foot that has outer guides on it, the issue with the gauge set I have is the presser foot has an center/inner toe that interferes with the guide. I like the one in the pic because the inner foot that is guiding is never interfered with by the outer presser foot, and the feet are holding all the way across the material- if that makes sense....
C
Not exactly sure what you mean. With: "interferes with" you mean inner foot touching the outer foot. Probably foot bars are not properly adjusted / centered? If well centered and it is just slightly touching you probably can grind down the feet a little bit.
Can you post pictures or a video?
send us a few pics of what you have so we can make a better recommendation to you.
glenn
By interfering I mean the inner foot is interfering with the material being guided in by the attachment. If you look at the pic below you can see the center toe pulls the material out of the guides on the inner foot. I may just need to grind down the center toe.....I just thought if there was a set of feet like the one initially posted above it would be an easy fix without modifying the current foot set.
On a side note, is there a good source of parts online for the Consew 745R, having trouble tracking a bobbin case down. Looks like the current one is a Seiko but there is no part number.
or lower the tape guide and / or set it further way from the foot towards the operator - but I only can guess cause I don´t know the whole setup.
