Members Sunny9072 Posted September 8, 2019 Members Report Posted September 8, 2019 Hi, I have a Consew 225, and I need to replace the screw that holds the needle in place and the thread guide screw. The thread guide screw is super tiny so I wondered if someone might know of a source that will for sure have that screw to sell. So, I need 2 different sized screws. I have attached a picture of the thread guide that needs the replacement screw. thread guide screw needle holder screw Thank you, -Sunny Insert other media Quote
Members Constabulary Posted September 8, 2019 Members Report Posted September 8, 2019 Check with a industrial sewing machine dealer - maybe Keysew in PA or Toledo Sewing Machines in OH. Needle screw should be the same as for the Singer 111 - for the other screw I would tab a new thread and add a common screw if you can´t find the original screw. Quote
Members Gregg From Keystone Sewing Posted September 9, 2019 Members Report Posted September 9, 2019 10535 Needle Set Screw 10681 Thread Regulator Set Screw Quote
Members Sunny9072 Posted September 10, 2019 Author Members Report Posted September 10, 2019 Thank you so much! I appreciate so much the knowledge you share here. I really need my machine back to work so, thanks again! -Sunny Quote
