Contributing Member JLSleather Posted November 6, 2019 Contributing Member Report Posted November 6, 2019 The Sig P238 is manufactured in nearly 100 variations (so I'm told). But - not including the HD - basically two slide widths. Question is, how do you identify WHICH slide width the person wanting the holster actually has? Not like you can help anything by saying "skinnier than the one you don't have" (they don't have it, so cant compare it). So... absent a caliper or micrometer... serial number? Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
CFM chuck123wapati Posted November 6, 2019 CFM Report Posted November 6, 2019 (edited) 35 minutes ago, JLSleather said: The Sig P238 is manufactured in nearly 100 variations (so I'm told). But - not including the HD - basically two slide widths. Question is, how do you identify WHICH slide width the person wanting the holster actually has? Not like you can help anything by saying "skinnier than the one you don't have" (they don't have it, so cant compare it). So... absent a caliper or micrometer... serial number? Most of the sig variations are in grips finish sights etc, the biggest difference in the frame or slide, for holster fit, I would think is if it is made with an accessory rail or not. Hope that helps I will keep looking through some of my books for barrels lengths and such. I see one built in 2010 that had a tactical laser mounted in front of the finger guard, most barrels are 2.7 or 3" so no biggie there. Edited November 6, 2019 by chuck123wapati moe info Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
wizard of tragacanth Posted November 6, 2019 Report Posted November 6, 2019 (edited) Yeah, I always thought that the only variation in the models was in the finish and the grips, I mean, a P238 is a P238 as far as I know. They don't come in different calibers or anything. I cannot imagine where or why they would differ. https://www.sigsauer.com/products/firearms/pistols/p238/ nick Edited November 6, 2019 by wizard of tragacanth added link to sig Quote Nick
CFM chuck123wapati Posted November 6, 2019 CFM Report Posted November 6, 2019 (edited) yea all im seeing is varations in grips, finish, sights, and what the slides or frames are made out of, all seem to measure 1.1" width, I don't even find any with acc, rails just the one model with the laser sights. yup found some more info two slide widths 11/16 or 13/16 seems they first used the thicker slides on the hd but now use it on other variations as well, seems to be a lot of trouble for the kydex holster crew also. I see some holster makers are asking basically which slide thick or thin, don't know how you could walk them through it any other way without measuring tools. Edited November 6, 2019 by chuck123wapati more info Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Contributing Member JLSleather Posted November 6, 2019 Author Contributing Member Report Posted November 6, 2019 13 minutes ago, chuck123wapati said: all seem to measure 1.1" width, Pretty sure that's talking about overall width.. including the grips 11 minutes ago, chuck123wapati said: found some more info two slide widths 11/16 or 13/16 Yeah, see now yer gittin what I'm talkin about. So WHEN did the change happen, and how would you have a customer identify that .. one who doesn't use a caliper or mic ... Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
CFM chuck123wapati Posted November 6, 2019 CFM Report Posted November 6, 2019 32 minutes ago, JLSleather said: Pretty sure that's talking about overall width.. including the grips Yeah, see now yer gittin what I'm talkin about. So WHEN did the change happen, and how would you have a customer identify that .. one who doesn't use a caliper or mic ... lol yea it wasn't a uniform change in width from what i'm reading so getting a serial number or year isn't going to do it. From what I have found the change was made in the hd models first then in the other models later as they were having problems with the narrower versions. Also from what I have read online sig isn't very good at answering that question. As far as customers, I haven't got a clue except to tell them there are two different widths, they may have to learn how to read a ruler its an 1/8" inch difference so they shouldn't need a caliper or mic for that. I guess they could use a fabric tape and measure circumference also. I'll look for more info. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
CFM chuck123wapati Posted November 6, 2019 CFM Report Posted November 6, 2019 Just went duh to myself while driving to the store, remove the slide lay it on top of a ruler easy peasy. Give them the measurements in mm as well as inches. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members thefallguy Posted November 7, 2019 Members Report Posted November 7, 2019 My understanding is the models that were upgraded with the larger spring assembly and thus the wider slide were serialized with the prefix "27A", and the subsequent design upgrades were prefixed with "27B". The Bluegun Store refers to the 11/16" version as a Pre 27A model which seems to support my assumption that the serial number is the best way to determine which model a customer has. I can't answer your question with absolute certainty, but so far this method hasn't steered us wrong. Quote
