Members JamesBlk Posted November 18, 2019 Members Report Posted November 18, 2019 Hi, I've been trying to find a double sided snap fastener, by which I mean domed on both sides, as in the attached picture. I feel like I may be using the wrong words to Google them or something. I thought about using a rivet as the second dome but I'm not sure if this would work, and it may not be exactly the same. The images attached are from a cable tidy on a very cheap charging cable so I didn't think they would be too hard to find. Thanks in advance for any help. James Quote
Members klutes Posted November 18, 2019 Members Report Posted November 18, 2019 Just use the dome post on each side. That’s what I have been doing. Quote Machines: Adler 69 , Adler 30-7, Adler 467, Cowboy bell skiver, Beilers embossing machine
Members JamesBlk Posted November 18, 2019 Author Members Report Posted November 18, 2019 On 11/18/2019 at 7:54 PM, klutes said: Just use the dome post on each side. That’s what I have been doing. Expand I should have tried that actually, the ones I have have a different type of post on the two section but I will give it a go. It would still be handy to find somewhere where I can buy a set with two domes so that I'm not wasting loads of bits. I know you can buy some separately but this only seems to be the case with expensive ones. Thanks Quote
Contributing Member fredk Posted November 18, 2019 Contributing Member Report Posted November 18, 2019 I've only had to cover a base a few times. Each time I just superglued the head of a ready-rivet on. I matched the colour of the head of the snap with the same in the rivet. Quote Al speling misteaks aer all mi own werk..
