Members akira7799 Posted November 19, 2019 Members Report Posted November 19, 2019 Hi All, I have a question regarding Harry Rogers YouTube video on his Singer 31K15. At approximately 4:16 seconds he talks about the tension pin on the inside of the tension assembly and how it's actuated by rotation of the cam. I looked for this particular movement in my Singer 31-15 and haven't seen it at all. There's not one part of the machine that touches this interior tension pin during the rotation of the cam. Overall question is, how different are the 31K15 and the 31-15. Should I be seeing this movement in my 31-15 machine? If I am supposed to see it, what adjustments can be made to ensure this pin will actuate properly during the cycle of the machine? If needed I can upload a video to show what I'm dealing with. Thanks, Dave Quote
Members Bert51 Posted November 19, 2019 Members Report Posted November 19, 2019 From memory this has been discussed before and sadly Harry did not know a lot about this machine as the pin he is talking about is the pin in the Tension adjuster and is moved but lifting the foot and not so cam some where. I was asked to correct this, but sadly he has not, so this myth still goes on. If you need any information about the 31-15 or 31K15 just ask this forum, as there is a lot of good peop[le who know heaps more then I do. Bert. Quote
Members Constabulary Posted November 19, 2019 Members Report Posted November 19, 2019 Agree with Bert! There is no tension release during the sewing cycle. The tension release is only required when you lift the foot lever and remove the material. As much as I like Harry´s videos but in this point he is wrong! The Singer 31 and 31K are the same 31 is US made 31K is UK made. The suffix K means Kilbowie, thats where the UK Singer plant was located once. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members akira7799 Posted November 19, 2019 Author Members Report Posted November 19, 2019 7 hours ago, Bert51 said: From memory this has been discussed before and sadly Harry did not know a lot about this machine as the pin he is talking about is the pin in the Tension adjuster and is moved but lifting the foot and not so cam some where. Thanks for the good news! I really manhandled this Formica and angle iron table (with machine on top) getting it into the truck and was deeply worried I broke/bent/busted a part. Otherwise, everything looks great! It only needed a very fine adjustment to hook/race time. Feed dog timing looked great. Thanks again for the reply. Quote
Members akira7799 Posted November 19, 2019 Author Members Report Posted November 19, 2019 6 hours ago, Constabulary said: Agree with Bert! There is no tension release during the sewing cycle. The tension release is only required when you lift the foot lever and remove the material. As much as I like Harry´s videos but in this point he is wrong! The Singer 31 and 31K are the same 31 is US made 31K is UK made. The suffix K means Kilbowie, thats where the UK Singer plant was located once. Thanks for the reaffirmation of information and the info on the 31K15vs. the 31-15. Very useful! Quote
Moderator Wizcrafts Posted November 19, 2019 Moderator Report Posted November 19, 2019 Sometimes companies or individuals have their machines modified to perform certain non-standard functions. Maybe Harry's 31k was previously modified to release the tension on the downstroke. I don't know why anybody would want this, but who knows. In contrast, there are some Singer machines totally lacking a tension release mechanism, like my 42-5. That's another story. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members akira7799 Posted November 19, 2019 Author Members Report Posted November 19, 2019 2 hours ago, Wizcrafts said: Sometimes companies or individuals have their machines modified to perform certain non-standard functions. Maybe Harry's 31k was previously modified to release the tension on the downstroke. I don't know why anybody would want this, but who knows. Thanks for the input. As far as I can tell mine doesn't appear to be modified and I'm thrilled/relieved that it's running the way "it's sposed to". Appreciate you input, Dave Quote
Moderator Wizcrafts Posted November 19, 2019 Moderator Report Posted November 19, 2019 3 hours ago, akira7799 said: Thanks for the input. As far as I can tell mine doesn't appear to be modified and I'm thrilled/relieved that it's running the way "it's sposed to". Appreciate you input, Dave I was referring to little Harry's 31k15 Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Bert51 Posted November 19, 2019 Members Report Posted November 19, 2019 cdthayer posted this some time back, "Four years ago, I tried to get Harry to take another look at his bull$hit about how “the Needle Crank lever should press the Tension release lever to push the pin that release the tension during the stitching cycle” (my post is at his Youtube video), and he didn’t reply. He replied to another guy and said that he no longer had the machine and couldn’t look into that person’s problem. Your needle crank shouldn’t hit the tension release linkage at all. Look elsewhere for your thread-breaking problem. CD in Oklahoma" Unless Harry had a SV 31K15, but to me it appear to be a normal Machine and if Harry cannot admit or clarify what he was talking about, then Harry has gone down in my opinion. Bert. Quote
Members akira7799 Posted November 20, 2019 Author Members Report Posted November 20, 2019 4 hours ago, Wizcrafts said: I was referring to little Harry's 31k15 Gotcha. Quote
