kgg Posted December 6, 2019 Report Posted December 6, 2019 8 hours ago, Dave84 said: I have a similar situation on denim, when there's a thicker part of folded over material then jumping to a thin, 2 layer section, make sense? Never could really find an answer as to why that is, plenty of foot travel. The problem maybe due to presser foot pressure. The setting to get good presser foot tension on the thick stuff maybe to light when you drop down to 2 layers or the foot is partially resting on the thick stuff while trying to sew the 2 layers. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Dave84 Posted December 8, 2019 Author Members Report Posted December 8, 2019 On 12/6/2019 at 6:41 AM, kgg said: The problem maybe due to presser foot pressure. The setting to get good presser foot tension on the thick stuff maybe to light when you drop down to 2 layers or the foot is partially resting on the thick stuff while trying to sew the 2 layers. kgg Yes, it is partial resting, continues to pull the lesser section causing some weirdness in the stitch line, but the thick part stays in place at the presser feet. Any solution on fixing that? On 12/6/2019 at 4:28 AM, chrisash said: Not really I am crap at it myself but just use the basic hand skiver, But it will make a large difference to your sewing if you do it Thanks, I'll start looking at it. Razor blades I have plenty of! Using garment leather seems to be extra tricky. Might just shift some of these extra folded parts around to balance out too much thicknesses. Quote
kgg Posted December 8, 2019 Report Posted December 8, 2019 You could maybe try a sample piece and play with the amount of pressure that you have set the presser foot at. I am going to assume that you are trying to sew across a hump of multi layers of denim. Any hump is always going to try and tilt the heel of the presser foot back. For that I would use a wedge. The wife's thick nail file /buffer would be the first likely candidate. As you are coming up to the hump, lift the pressure foot up with the needle in the down position through the material as if you were going to make a turn, slide the wedge under the back of the presser foot and let the presser foot back down. That should keep the pressure foot level and allow it to sew over the hump. That combined with a little tugging on the thinner material to prevent over feed of the material should help. I would also experiment with adjusting the amount of pressure on the presser foot (thicker materials need less pressure foot pressure then thin). kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Dave84 Posted March 17, 2023 Author Members Report Posted March 17, 2023 On 12/7/2019 at 8:15 PM, kgg said: You could maybe try a sample piece and play with the amount of pressure that you have set the presser foot at. I am going to assume that you are trying to sew across a hump of multi layers of denim. Any hump is always going to try and tilt the heel of the presser foot back. For that I would use a wedge. The wife's thick nail file /buffer would be the first likely candidate. As you are coming up to the hump, lift the pressure foot up with the needle in the down position through the material as if you were going to make a turn, slide the wedge under the back of the presser foot and let the presser foot back down. That should keep the pressure foot level and allow it to sew over the hump. That combined with a little tugging on the thinner material to prevent over feed of the material should help. I would also experiment with adjusting the amount of pressure on the presser foot (thicker materials need less pressure foot pressure then thin). kgg Hi KGG, I'm updating this thread and would like your help. My Adler has been working just fine on denim, other heavy fabrics and light leather and will keep it for those projects. Now, after doing several jackets, some perfect, larger percentage still having this issue although tamed immensely over the years, I'm done with my system of avoiding as best as possible all above. One comment mentioned hitting the limit of this Adler 167-373, so what machine would be the next step up for jacket making, bags, wallets? I'd like to stay with a name brand for easy parts and service. Thanks! Quote
Members Aven Posted March 17, 2023 Members Report Posted March 17, 2023 Hand skiving takes a bit of practice, but it is a skill worth learning. Do a search for Lisa Sorrell Skiving Youtube. She has two, maybe three videos about skiving and skiving knives. They are well worth your time. Quote
kgg Posted March 17, 2023 Report Posted March 17, 2023 27 minutes ago, Dave84 said: One comment mentioned hitting the limit of this Adler 167-373, so what machine would be the next step up for jacket making, bags, wallets? On 12/4/2019 at 12:33 PM, Dave84 said: Material thickness I'd say is 3/8" to 1/2", folded over buffalo hide of 1mm if I remember correctly. I would first suggest taking a sample of the thickest, including seams, of material or leather to a machine dealer and test drive a few machines. I would in a flatbed suggest looking at compound sewing machines that have the minimum sewing capacity of the Juki 1508 NH but you maybe once again be at their rated sewing limit. Once you get into needing too sew 1/2" thickness you are really, I think, needing a Class 441 machine. That would in a flatbed probably put you into a Juki TNU-243U or a Juki TSC- 441 cylinder bed with a flat top attachment. Both machines are grossly expensive probably north of $10,000. For most the cost is prohibitive so I would suggest looking at machines similar to the Cowboy CB 243 flatbed or in a cylinder bed the CB4500 with a flat top attachment. The cost of those machines are probably in the $3000 to $3500 range. I would stay with Juki or clones as accessories, replacement parts are cheaper and more readily available then say PFAFF and Alder. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Dave84 Posted March 17, 2023 Author Members Report Posted March 17, 2023 (edited) 18 minutes ago, kgg said: I would first suggest taking a sample of the thickest, including seams, of material or leather to a machine dealer and test drive a few machines. I would in a flatbed suggest looking at compound sewing machines that have the minimum sewing capacity of the Juki 1508 NH but you maybe once again be at their rated sewing limit. Once you get into needing too sew 1/2" thickness you are really, I think, needing a Class 441 machine. That would in a flatbed probably put you into a Juki TNU-243U or a Juki TSC- 441 cylinder bed with a flat top attachment. Both machines are grossly expensive probably north of $10,000. For most the cost is prohibitive so I would suggest looking at machines similar to the Cowboy CB 243 flatbed or in a cylinder bed the CB4500 with a flat top attachment. The cost of those machines are probably in the $3000 to $3500 range. I would stay with Juki or clones as accessories, replacement parts are cheaper and more readily available then say PFAFF and Alder. kgg Thanks KGG. To see if I understand, the Adler 167 I have is an upholstery grade which I believe does have 1/2" of lift, but isn't strong enough to handle denser seams. The next step up into walking foot industrial machines is a significant jump to $3000-$10000. Does Juki make a medium duty leather sewing machine that can handle heavier garments? 30 minutes ago, Aven said: Hand skiving takes a bit of practice, but it is a skill worth learning. Do a search for Lisa Sorrell Skiving Youtube. She has two, maybe three videos about skiving and skiving knives. They are well worth your time. Aven, Thanks for the reply. I hand skive veg tan for bags and belts but will definitely research the videos. I'm currently using .08 chrome tan for the jackets and hand skiving I've not had success with. Edited March 17, 2023 by Dave84 Quote
kgg Posted March 17, 2023 Report Posted March 17, 2023 3 hours ago, Dave84 said: To see if I understand, the Adler 167 I have is an upholstery grade which I believe does have 1/2" of lift, but isn't strong enough to handle denser seams. The upholstery grade machines have about 1/2" presser foot lift but you have to subtract about 1/8" from that for sewing purposes. This means you should be able to sew about 3/8" of material depending upon such things as how tough, how sticky the material is, needle thread combination, etc. 3 hours ago, Dave84 said: The next step up into walking foot industrial machines is a significant jump to $3000-$10000. Yes there is a large price jump once you go above the capability of sewing consistently greater then 3/8". 3 hours ago, Dave84 said: Does Juki make a medium duty leather sewing machine that can handle heavier garments? Yes Juki does have medium duty machines that are rated for 3/8" like the compound feed Juki DNU-1541"S" flatbed and the compound feed Juki LS-1341 cylinder bed but once again if you are consistently sewing in the 1/2" or greater you are probably going to run into the similar problems. The compound feed on those machines (needle. feed dog and presser foot) will help to move the material along much better then the ordinary walking foot machines. The price of those machines: Juki DNU-1541"S" about $1800 USD and the Juki LS-1341 about $5500 USD. If you can figure a way around reducing the seam thickness like skiving by hand or by machine to be around 3/8" or under then i) price of a new machine becomes reasonable ii) you may not have to replace your existing machine. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
