Members studio6f Posted December 6, 2019 Members Report Posted December 6, 2019 New here - hope this is the right place to post! I am refurbishing a leather sling Bruno Mathsson for Dux Jetson chair from the 1960's. I have a quilted seat cushion attached to the leather sling of the chair via standard steel grommets with a 3/8" hole. In order to attach the grommets to one another, the chair had some sort of Chicago Screw that secured them. I only have 3 of these, but am needing a total of 12. I don't mind straying from the original, my only trouble is that I need something with a head of 12-14mm, which has been absolutely impossible to find. I am attaching images of the original screw - a sort of tunnel with serrated edge. Is this even a Chicago screw? Or some sort of screw grommet? All assistance is appreciated! Thanks! Quote
Members Handstitched Posted December 7, 2019 Members Report Posted December 7, 2019 What a job you've taken on Have you tried contacting ' Dux Jetson' themselves? http://www.dux.com/Furniture/armchairs/jetson/ http://www.dux.com/About-DUX/Contact/ They may have a contact to someone that has spares for these chairs? No harm in asking eh? You may have to do a bit of ground work on the 'interwebiverse ' on this one . Or you could do a simple search: ' screw posts 12mm ' ? Good luck HS Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
Members Matt S Posted December 7, 2019 Members Report Posted December 7, 2019 Welcome to the forum, @studio6f. Consider adding your approximate location to your profile, so that people can make locally-appropriate responses. Depending on budget, I'd try to find someone local with a lathe. Preferably a retired person or other hobbyist, rather than a proper machine shop as they will probably be more amenable to a job like this and you might be able to pay with goods or services rather than money. Quote
