Hi there
Just looking for thoughts on how to lessen the pressure foot marks that my singer treddle machine leaves on my projects?
Thanks
1 hour ago, Rbarleatherworks said:
Hi there
Thanks
You forgot to mention the model number of the machine. If you don't know it, take a small resolution photo of the operator's side of the machine and upload it in a reply. Then we who might respond will know what to tell you about where the pressure adjustment is on the head. Also, tell us if there are teeth on the bottom of the presser foot or feet.
Posted IMHO, by Wiz
ooops Sorry  ... its a 29K51, this is not a pic of it but it is very similar the only difference I see is that the wheel is on the end.
and yes there are teeth on the bottom, that is what is marking the leather.  I can pound some of the marks out but not all.   So was just hoping to find a way to lessen the problem all together.
Thanks
Edited by Rbarleatherworks
to add more to the post
Well patchers have teeth on their presser feet because thats the way they feed the material. If you had a vintage 45K you would have feed dog marks as well but on the underside. The presser foot is kind of feed dog but on the top side. I would first try to reduce the foot pressure as far as possible. You can try a piece shrink hose on the foot but the machine will probably no longer feed the material as good as before. There once was a guy here who  coated the foot with diamond dust or the like (do not recall what it was)  if I recall correctly that worked well for him.
Let me check if I can find this old post....
EDIT:
found it ;)
Edited by Constabulary
You can back off the foot pressure by turning the wide thumb nut on the top left rear of the revolving head housing. You can see the coil spring inside a channel on the rear of the head.
Posted IMHO, by Wiz
Thank you Wiz & Constabulary ... I will try that nut and have a look at that article :)
