Hello,
I’m having such an annoying problem with my “JACK JK-513A” servo engine.
The engine is connected to my “JUKI DDL-8700”.
So here’s the issue: The engine won’t go any faster than 02 in speed... Even though the speed is set to 20-30. Everything worked fine just the other day. Today when I started to sew, I received an "E5 error" — after I solved the error, it seems like the machine won't sew any faster than 02.
Please check the following demonstration video by clicking the link: Demonstration video
Does anyone have an idea, of what I can do?
(Btw. thanks for letting me join the community)
W/o knowing details, so I guess you set the speed correctly (don`t know - video is too fuzzy and is not playing well on my end). So I would guess in the accelerator unit the lever with the magnet is not properly set. I guess it is too far back (away from the hall sensor). I guess you have to move it towards the hall sensor a little bit.
I only can guess... so I would recommend contacting College Sewing or the dealer you bought the motor from.
Edited by Constabulary
@dikman @Constabulary So I've tried to reset to factory settings, without any luck — because the machine still didn't work correctly. When I reset to factory settings, the display shows "OK", meaning the reset was successfully done.
I wonder if it might have anything to do with the speed governor? It just seems very strange to me...
Here's the manual: http://en.chinajack.com/DownLoad/201706271100232.pdf
The manual is not exactly made for the same model, it seems (not sure tho).
Image of E5-error
Link to a demonstration video
I think with speed governor you mean what I called accelerator unit - the small squared box with the white plastic lid and the small lever on the outside. When you open it (3 screws)  you see a small black lever and I think it is too far away from the hall sensor - the small black thingy with 3 poles which is soldered on a  small green board. You probably have to play with the position of this black lever.
