Have been researching various cylinder arm machines, just wondering if anyone has actual experience with the Techsew 2600 Pro and/or the 2750 Pro machines.  Would appreciate any first hand knowledge regarding these machines.
Thanks,
Steve
I have a TS 2700 that I bought used from another member of this forum. It is a good medium duty walking foot machine. The table is U shaped. I use a short stool to operate it. The maximum thread is #138, but I don't need to use it in this machine. It does fine with #46, 69 and 92 bonded nylon thread.
One thing I changed was the motor. I don't know what motor is standard now, but this machine had a brushless push button controlled servo that started spinning with a jerk at about 200 rpm. I bought a Family Sew FS-550s and a speed reducer and that problem is history.
Posted IMHO, by Wiz
I also have a TS 2700.  My experience with the servo is much the same as Wizcrafts.  Also replaced with a FS-550 and speed reducer.  Good machine, no complaints. Also use 138 thread, and sometimes 207 on the top.  Takes some time to adjust tension when you keep swapping thread sizes for different projects.
Tom
