Members Omer Posted December 17, 2019 Members Report Posted December 17, 2019 (edited) Good evening, just for the record I’m new here, I’m not sure if this is the right place to post this, but here goes i just purchased a singer 29k 62, it was sewing with big hoops at the bottom so I played with the tension and it got better, but know I’m getting hoops on the top only, after sewing about 2 inches or moving the needle to the side while sewing Edited December 17, 2019 by Omer Quote
Members Constabulary Posted December 17, 2019 Members Report Posted December 17, 2019 (edited) 3 hours ago, Omer said: but know I’m getting hoops on the top only, after sewing about 2 inches or moving the needle to the side while sewing  Not sure what you mean with moving the needle... Loops on top or bottom is usually a tension problem or you have a problem with your thread path or parts that put tension to the thread. Can you post some pictures of your machine and how you have threaded the machine? I´d also check the paddle shaped check spring on the needle bar if it is worn (grove of inside of the paddle end). Guessing you already have a manual, if not I attach one here. Manual Singer 29K62.pdf Edited December 17, 2019 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Northmount Posted December 19, 2019 Report Posted December 19, 2019 @Omer Moved your post to Leather Sewing Machines. On 12/16/2019 at 10:27 PM, Constabulary said: Not sure what you mean with moving the needle @Constabulary I think he means turning the presser foot to change directions? Just a guess! Tom Quote
Members Omer Posted December 22, 2019 Author Members Report Posted December 22, 2019 Yeah when turning the pressure foot while sewing Quote
