Hello,
Can someone tell me if the needles I use in a Juki 1541S can be used in a Pfaff 335 clone?
134-35  & 135 x 16: Are they compatible?
Thank you!
Silverd
You basically can use either needle in either machine when you adjust the needle bar height. 135x16 is a little bit longer than 134-35. So if you want to use 135x16 in your Pfaff 335 clone you have to raise the NB by the amount the the 135x16 is longer than the 134-35. Looks like approx 0.8mm + some fine tuning. Measured from end of shank to right above the needle eye.
I have set the majority of my machines to 135x17 / 135x16 just for the reason that I do not have to stock different needle systems.
Some technical data sheets from the DOTEC website:
image.png.af5ee12f3daccf86777a33fb90ed6c98.pngimage.png.4e60c863346f7aa89a7b6ba590642bba.png
Edited by Constabulary
I have done the same with most of my machines C including the new DA669.  I have not problems.
glenn
Wow!  Great information. I'll be attempting to make that adjustment as well in that case.
Many thank Gentlemen!
Silverd
