I've run across a very  nice looking Consew 228 R 11 Post Bed machine.  That said, I know enough to be dangerous when considering a new machine.  My wife makes handbags of various kinds, and got her a new Juki 1541S a few weeks ago, super machine.  The subject post bed machine is equipped with the servo motor and the T-leg table, no speed reducer.  Did a bit of looking and found out that it is a roller feed machine.  Would this be a good addition to her workshop or would a cylinder arm machine be better.  Is the Consew 228 xxxx a good machine or is this worth considering?  Probably could get it for $1200 or a bit less...what do you all think?
Steve
Maybe these videos of the Consew 228R-11 in action will help you decide.
Posted IMHO, by Wiz
Wiz, thank you for those informative videos.  Are there any "land mines" with this machine that one should be aware of?  Is 1200 a good price ?    I truly do not know..
Thank you,
Steve
Thank you,
Steve
Not landmines, but practical limitations. This machine is not meant for heavy thread or thick work. Most people buying this machine are detailing items that are under 1/8 inch thick and soft temper, using bonded thread sizes 33 through 69. It possibly can sew thicker and use #138 thread, but the roller foot only holds down the left side. A #22 needle loaded with #138 thread will probably lift the leather up as it tries to come out with the lockstitch knot. This leads to skipped stitches and ruined projects. Practically, if sewing leather, I wouldn't recommend using thread larger than #92, with a #19 leather point needle, into about 8-9 ounces or so. If sewing cloth or man-made materials, it can handle about 1/4 inch, with #92 thread.
The machine uses G size bobbins and System 134 needles. Here is the Consew product page for the 228R-11-1.
Posted IMHO, by Wiz
Wiz, thank you for all your insights on the machine.  We went and checked it out, Carolyn sewed on it, it will work very nicely on the leather thicknesses that she is making handbags and purses.  The machine is 4 years old and the sellers purchased it new, only has about 3 months use on it. Very clean and slick machine.  Almost cannot tell it from new.    The standard thread she uses is 69 in her bag making.  The lady who had this machine has another just like it, but with a SR-2 speed reducer on it.  She had this machine as a back up, and decided that she did not need a back up machine.  This one I will have to add the speed reducer to it.  That will add about $165 or so to the investment, so I think we're still ok.   I think this machine will allow her to do some 3 dimensional work that she can't do on the flatbed, or it will make some of the awkward work she's done on the flatbed a piece of cake....
Thanks again,
Steve
I'm glad to have helped you make this choice. I love my Singer 168 post machine.
I got a box style reducer for my post machine. The box bolts to the table and the motor bolts to the bottom of the box. this keeps the long belt in about the same position as the original, allowing you to tilt the head back for servicing. Another machine of mine has a 3:1 stand-alone 3 pulley reducer bolted under the table, along side of the belt cutout. The belt from that reducer is more or less directly inline with the head and has to be loosened to tilt the head. It also changes the position of the bobbin winder. Consider the box type reducer. Toledo Industrial Sewing Machines sells them.
Posted IMHO, by Wiz
Wiz, looked at Toledo website did not find any link to the box type speed reducer.  Approx what do they cost and do they end up with the same reduction as the 9" pulley type?
Wiz, thank you for your advice on the box type speed reducer.  Ordered one from Ed at Indianapolis yesterday, Ed is a very interested in getting his customers fixed up in the right way.
Steve
Wiz, took your advice and got a box type speed reducer for the Consew 228 R11.  It arrived today, and I got it installed this afternoon, 3 trips to O'Reilly's to get the correct length belt...agh.....had to lower the rear brace on the T-leg table frame all the way down to clear the servo motor, but it worked out slick!  Very glad you put me on to this box type speed reducer instead of the pulley type.....lots better!
 This is a made in Japan Consew machine, and apparently Seiko manufactured them for Consew?  Are the Japanese mfg machines are better made than the Chinese made ones?  I think this machine is going to be a good one, it is 3 1/2 years old and only got used for 3 months, according to the seller.  I believe the reason they sold it was that it did not have a speed reducer on it, and their other post machine did have one on it.  You almost cannot tell this is a used machine....should work out good for my wife making leather handbags..
Thanks again for your wisdom and advice!
Steve
