Members HondoMan Posted March 1, 2020 Members Report Posted March 1, 2020 (edited) Right then, I never really picked up the good habit of sharpening, much less polishing blades. No sure why, just never worked it into me life. Then I got into leather and no only did I need this wee proper skill, but have become rather good at it. Have several methods for various blades and all goes right well. The slight exception is the awl blade. I only use Blanchard awls. The normal routine is to use a Whetstone (with honing oil) firstly, then to a diamond stone. Once I get a good edge, I then use dampened (water) sandpaper (3600, 8000 and 12000 grit) and I get a lovely polished edge that goes through leather like butter. Been reading quite a bit about stones to be better educated. I use a ceramic stone (3000 / 8000) for me knives and a strop for polishing. Lately, I've been wondering if a ceramic stone would be good or better for the awl blades and completely forgo the whetstone and diamond altogether. I read on a few websites that if one plans to polish a blade, ideally skip the diamond stone altogether. Me concern is how one sharpens an awl blade versus a knife blade and whether it's wise for the ceramic stone and wee awl blade. I could easily purchase a ceramic stone to test, but don't wish to hurt either the stone or awl blade. Thoughts? Cheers! Edited March 1, 2020 by HondoMan Quote http://lederwaren-allgäu.de/ https://www.instagram.com/scottishknightleather/
Members Tugadude Posted March 1, 2020 Members Report Posted March 1, 2020 (edited) Nigel Armitage put out a video on how he prepares awls. Might be helpful. Edited March 1, 2020 by Tugadude Added link Quote
Members gotafly Posted July 14, 2020 Members Report Posted July 14, 2020 I use a ceramic fishing hook sharpener. They are V shaped and usually have several grades of grit all the way to fine which does a beautiful job of polishing. Quote
CFM chuck123wapati Posted July 18, 2020 CFM Report Posted July 18, 2020 (edited) I sharpen my awls different than Nigel. I sharpen a flat on the tip and polish the sides this way i dont have to sharpen all four sides but i can just run it across a piece of 2500 grit sand paper i have glued on my hammering stone. i do this by using one of the four edges as the tip then simply angle a bevel down to the opposite edge. I can then always see the leading edge put my finger on it and keep my holes running the same direction I polish or reshape the sides by holding my awl flat on the edge of the stone and use my small stone or a piece of sandpaper wrapped or glued to a flat steel polishing it. I find its easier for me to keep the edges parallel and straight by moving the paper or stone and keeping the awl steady, kind of like using a file on something. i dont know if i can load my picture the site is kind of jacked today and i have no attach button on this. Edited July 18, 2020 by chuck123wapati tried to add a picture, it failed. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
CFM chuck123wapati Posted July 19, 2020 CFM Report Posted July 19, 2020 (edited) On 7/18/2020 at 11:09 AM, chuck123wapati said: I sharpen my awls different than Nigel. I sharpen a flat on the tip and polish the sides this way i dont have to sharpen all four sides but i can just run it across a piece of 2500 grit sand paper i have glued on my hammering stone. i do this by using one of the four edges as the tip then simply angle a bevel down to the opposite edge. I can then always see the leading edge put my finger on it and keep my holes running the same direction I polish or reshape the sides by holding my awl flat on the edge of the stone and use my small stone or a piece of sandpaper wrapped or glued to a flat steel polishing it. I find its easier for me to keep the edges parallel and straight by moving the paper or stone and keeping the awl steady, kind of like using a file on something. i dont know if i can load my picture the site is kind of jacked today and i have no attach button on this. But my awls aren't shaped the same as a blanchard, if they were I would keep the point as manufactured but i would still hold the awl still and at the right angle and move the sharpening stone across the blade. Edited July 19, 2020 by chuck123wapati more to add Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
