Hi. I'm new to this forum and leather crafting, I watched dozens of videos from tandy on YT. I did every step carefully .But in the end my panda looks kinda stiff or I should  say like hewn stone :)  How to get smooth carving lines?
Thanks for any advice
Edited by VanBandama
 practice, practice, practice and more practice..... check out youtube channel Joe Meling or facebook 23+ for some tips and tricks.....
bobby
You will find that mallet/maul weight matched to tool  has a lot to do with it. Being able to pick a 'whacker' that is just right and needs only gravity and guidance will help a lot (over the years, I have accumulated~ 20 different weights from 6 oz to 3 lbs and use them all in a large, complex pattern) I find that with practice (years) I can control the force delivered more exactly and switch less often.
I feel the most important factor in smooth carving is having a sharp swivel knife blade.  You will be surprised at how much easier carving can be.  The other thing I see is you are leaning the knife and undercutting on some of your curves. What Oldtoot said is awfully important also
Terry
Edited by terrymac
Addition
