Members Miquel Posted May 10, 2020 Author Members Report Posted May 10, 2020 I have enlarged the arm adding a piece of metal. Now the lever law is working efficiently. Of course, must to make a hole on the table for pass the chain. Now, with the feet can go up the presser foot without any effort. More control too, due that no need to make big effort and you know exactly what amount of strenght are using. Before too much strenght and loss the control, then the chain can be broken... I just put again the stronger spring on the lever foot assembly. No need to put a weaker one. Just a little bit of work, no need to make anything with the machice, just unbolt two bolts and re-bolt again with the added arm. Quote
CowboyBob Posted May 10, 2020 Report Posted May 10, 2020 I'm glad to see you got it fixed,pretty easy too!! Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members Miquel Posted May 11, 2020 Author Members Report Posted May 11, 2020 'Thanks Bob, very happy with the machine. I have It almost ready. Whit suspended guide, the extra large handle for presser up the, flat needle plate, feed dog without teeth...Almost ready. Only need some needles. So difficult to buy needles in Spain, only can find LR points and need to buy minimum 50 needles... I would like to buy some S and LL points for make straight stitches, but difficult and must to buy 100 needles per size...So, a small fortune if want to buy some sizes too... This is the beast: Quote
Members Constabulary Posted May 11, 2020 Members Report Posted May 11, 2020 (edited) for needles check with College Sewing in the UK https://www.college-sewing.co.uk/catalogsearch/result/?q=794+needle Not worth buying just a pack of needles but you may find other useful things too. Edited May 11, 2020 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Miquel Posted May 11, 2020 Author Members Report Posted May 11, 2020 Thanks Constabulary, at least have bought some S points, different sizes. Itis apity that can not buy the LL points for check It, but S points would be fine. Quote
