James Roberts
Wanted: Throat Plate for Singer 42-5 (part 8192)
Hello,
I am refurbishing a Singer model 42-5 Industrial machine and am missing the throat or needle plate, specifically part no 8192 (if you have a different throat plate I would need the appropriate feed dogs, presser feet as well).
Hopefully someone can help me.
The plate should be ~56mm wide, 86mm deep and a bit under 2mm thick, there should also be 60mm between the two screw holes.
Cheers, James (Australia)
Edit: Just realised this should probably be in the wanted forum, if so maybe a moderator could move it.
Edited by James Roberts
Posted to wrong board?
