Members Silky Posted June 24, 2020 Members Report Posted June 24, 2020 (edited) Anyone here familiar with this model ? Is it a Consew ... of sorts ? I'd like to know its capacity, and if it has the big bobbin. Thanks for looking. Edited June 24, 2020 by Silky Quote
Members Constabulary Posted June 24, 2020 Members Report Posted June 24, 2020 (edited) Base model is the Singer 211U which came in a lot of different sub classes. Open the right slide plate and remove the bobbin - is approx 25mm (or larger) its a large bobbin if 22mm its a small (standard) bobbin. These machines usually sew up to 9mm some up to 12mm depending on how it was set up. Best bet is test if before you buy it. Edited June 24, 2020 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Silky Posted June 24, 2020 Author Members Report Posted June 24, 2020 Thank you Constabulary I may go look at it. It's on a table with a clutch motor. Asking $100. Quote
Members Gregg From Keystone Sewing Posted June 24, 2020 Members Report Posted June 24, 2020 (edited) Mitsubishi DU-105, old world Japan quality on par with Juki and Seiko. It's actually a really good machine. 135X17 needle, same large bobbin as Juki LU-563, popular Singer walking feet same as 111W155 or Consew 206RB. See attached owners manual. Mitsubishi DU-100, -120 Instruction Manual.pdf Edited June 24, 2020 by Gregg From Keystone Sewing Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Members Silky Posted June 25, 2020 Author Members Report Posted June 25, 2020 Thanks for that Gregg. If I didn't already have a 211G166 I would have gone after it ! But, at $100 it didn't last long and is no longer available I'd really like the larger bobbin. Cheers. Quote
