Members mishka Posted July 22, 2020 Members Report Posted July 22, 2020 Hey Guys, here is my latest project I did for myself. Here is my first attempt at this, learned few things from it Next I want to try to make a sling for it. What weight leather is recommended for it? And is there any good templates? Quote
Members Scootch Posted July 24, 2020 Members Report Posted July 24, 2020 Looks real nice. I like the rifle too! What type of sling are you thinking about? padded, simple strap, sued lined, used just for shoulder carry or to support off hand shooting... I've yet to make a sling but I'd probably use an 8oz veg tan and add a 4oz sued liner on the shoulder area. I don't really care for a padded sling. Maybe some others will chime in. Scootch Quote
Members Josh Ashman Posted July 24, 2020 Members Report Posted July 24, 2020 Very nice Miska! My personal preference for a sling on this type of rifle is a simple straight strap either 1" or 1-1/4" wide built out of 10 to 12 oz leather with some adjustment possible with either laces holes or a conway buckle. I've attached a pic of one of my similar rifles with a sling made just this way. All the best, Josh Quote
Members mishka Posted July 24, 2020 Author Members Report Posted July 24, 2020 Thanks guys. Was thinking some simple two/three piece cobra style with no padding. Planning just adding the same border stamp to match the butt stock. But I quite like yours Josh too. If i decide to do without any lining or padding, whats the best way to finish underside of the leather? Dye it , then Gum Trag and slick it up? Quote
Members Josh Ashman Posted July 27, 2020 Members Report Posted July 27, 2020 On 7/24/2020 at 2:42 PM, mishka said: If i decide to do without any lining or padding, whats the best way to finish underside of the leather? Dye it , then Gum Trag and slick it up? It depends a little on the hide you're using and where you're cutting your sling. If it's "strap" or "tooling" leather that has been made a uniform weight at the tannery and you're cutting closer to the top or back of the hide it'll likely be fairly smooth already. I'd just dye it, oil it to the degree you like then top coat it with whatever you like. If it's "fuzzy" for whatever reason and it's plenty thick to allow it you can use fine sandpaper wrapped around a wood block and sand it smooth. I like to sand in one direction and have the leather slightly cased. You can also "slick" it down using a glass slicker or smooth hardwood block with the edges rounded and fine sanded glass like smooth. You'd have the leather cased and smooth the grain down going in one direction. Both of these are good options If you're using skirting leather that hasn't been split to an even weight at the tannery. If the leather is fuzzy because it's from the belly you may re-think using it for a sling as belly tends to be stretchy. I haven't used Gum Trag for many years, it always seemed to me like plain water got about the same results. At the same time I have nothing against it either, for me it was just one less thing to buy. Good luck with your sling! Josh Quote
Members Oldhnery1 Posted September 12, 2020 Members Report Posted September 12, 2020 Nice work Mishka. I like what you've done here. The wrap on the cocking loop is especially nice!! Quote
