CFM Frodo Posted July 22, 2020 CFM Report Posted July 22, 2020 how do you set these 5mm dome rivets? i understand you set the glass down on the mat and strike the cap with the setter that does not work. any tips? Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
Members billybopp Posted July 22, 2020 Members Report Posted July 22, 2020 Wet a thick piece of leather - or even a few layers to make thick - put the rivet head on it and hammer from the backside. The leather will make a form for it that'll work from then on to support the rivet. That little trick works for all sorts of oddly shaped rivets. I set a ton of skull rivets and some others that way. - Bill Quote
CFM Frodo Posted July 22, 2020 Author CFM Report Posted July 22, 2020 On 7/22/2020 at 11:27 PM, billybopp said: Wet a thick piece of leather - or even a few layers to make thick - put the rivet head on it and hammer from the backside. The leather will make a form for it that'll work from then on to support the rivet. That little trick works for all sorts of oddly shaped rivets. I set a ton of skull rivets and some others that way. - Bill Expand thanks bill. the setter i was sold is crap Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
Moderator Wizcrafts Posted July 23, 2020 Moderator Report Posted July 23, 2020 I have a bunch of domed cap rivets in various diameters and bought concave setting tools to match them. I haven't had any problems setting them as long as I use the correct setter. You may have received the wrong setter. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
