Members AMule123 Posted September 9, 2020 Members Report Posted September 9, 2020 Hey all! so I recently picked up a seiko ch-8b and have been having a good old time playing around. Problem is when in reverse the stitch length is roughly halved, which doesn’t make for a neat finish. Thing is the previous owner removed the feed dog and fitted a slotted plate, and I saw somewhere on here someone mention the same issue after this modification. so I replaced them, and not only did it not fix the stitch length, now the tensions out on the reverse! The manual I’ve found hasn’t been of any help, and it doesn’t seem to be all that common of a machine, so being a relative machine noob, I’m having a bit of trouble. Thanks in advance! sam Quote
Members AMule123 Posted September 10, 2020 Author Members Report Posted September 10, 2020 so after more reading, ive learned that im looking to balance the forward and reverse stitch length and tension. Would a machine specific manual exist that would show me adjustments like this? would it be worth contacting seiko? Quote
Members Handstitched Posted September 10, 2020 Members Report Posted September 10, 2020 G'Day from a fellow Aussie Not sure if this is of any help: https://leatherworker.net/forum/topic/77410-seiko-ch8b-manual/?tab=comments#comment-512159 HS Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
Members Handstitched Posted September 10, 2020 Members Report Posted September 10, 2020 Not sure if this is of any help as well: https://www.sewingmachinery.com/seiko/seiko-ch-8b.html Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
Members AMule123 Posted September 12, 2020 Author Members Report Posted September 12, 2020 thanks guys! The manual for the 757 was helpful, but also a bit cryptic, for instance; "Determination of positioning for stitch length at forward and backward amount." granted, theres lot a i need to learn about sewing machines, but thats nonsense right? haha it goes on to say that it can be adjusted by the position of the feed regulating set plate, which as far as im aware would only change the maximum stitch length, and not affect the reverse length. am i wrong? might be time for me to call the dealer haha thanks again guys! Quote
Members Ares667 Posted October 24, 2021 Members Report Posted October 24, 2021 Good evening I have been reading this great forum for a long time and have learned a lot here. Now I have bought a Seiko ch-8b and have the same problem with the machine as described by Emule. With the reverse stitch, the machine only makes half the stitch width of the previous stitch ... I have already read through the Consew instructions. But unfortunately that didn't get me much further ... It seems to me as if the feed regulating lever is shifted upwards in the zero point. But unfortunately I absolutely cannot explain to myself how to regulate that. Hopefully someone can help me here. (And please excuse my bad english, I'm not a native speaker.) Best regards Quote
Members Cumberland Highpower Posted October 24, 2021 Members Report Posted October 24, 2021 I've never owned a CH8, but used one briefly 20 years ago. I liked it from my vague memory, but I have read of many that didn't. Seems like they don't hold up or stitch as well as a Juki or Adler and have fewer feed available? Sounds like a timing issue. I believe you can balance the stitch length, but I don't have any way to help out there sorry to say. Quote
