No rivet! Proper stitching is stronger than a rivet anyway. I have tested this myself and the stitching holds up better under stress. Assuming of course there is a welt as previously mentioned. I agree that rivets are used on cheap stuff.
15 hours ago, DaveP said:
Thanks for the kinds words on my sheath!
No rivet it is! Now I have only been doing 2 back stitches so far. Do any of you put more than that in?
 Thanks again
If you used an awl to make the holes, and you did the stitching right, 2 back stitches should be just fine.
The only reason I say that is I've seen people drill out the holes and then there's not much leather to close back up tight on the stitches.
I'm not drilling the holes. I used a stitching chisel and slightly opened the back from the front with a small diamond awl. All seams are glued with contact cement as well.
