also check the spring i in the needle bar above the needle clamp,  Machine sews good but a lot of slack in the needle thread as it enters the leather you were sewing,  Spring may have a grove worn in it or be broken.
glenn
  • 4 years later...
привіт всім У мене також є модель Singer 29k 31 і я маю дуже маленький стібок (2 мм), який більше не регулюється, з чим це може бути пов'язано? Дякую і перепрошую за мою англійську, тому що я пишу вам через перекладача.
Hello everyone. I also have a model singer 29k 31 and I have a very small stitch (2mm) which is no longer adjustable, what could this be related to? Thank you and I apologize for my English, because I am writing to you through a translator.
Increasing the foot lift and decreasing the foot pressure can help to gain a little bit stitch length. Other than that it most likely is the bell crank lever tip that is worn down. You can buy made in China Bell Crank levers new but you often have to modify them to make them work for the ancient 29K models. Some years ago I did that on a 29K1 and it worked. Or you rebuild the bell crank lever tip by brazing or welding and file it into shape again. The tip diameter is ~5mm on a new bell crank lever. But keep in mind other parts on your machine may be worn too so it could be more than just the bell crank lever.
This was my restoration 10 years ago:
https://leatherworker.net/forum/topic/60554-29k1-pre-christmas-barn-find/
And this is the bell crank lever
https://www.ebay.com/itm/162385595622?
