Members Arturomex Posted November 12, 2020 Members Report Posted November 12, 2020 5 hours ago, paloma said: better than USMC one? I think so. It seems to have better penetration without leaving a lot of stuff on the surface. Regards, Arturo Quote
Members paloma Posted November 12, 2020 Author Members Report Posted November 12, 2020 3 hours ago, Arturomex said: I think so. It seems to have better penetration without leaving a lot of stuff on the surface. Regards, Arturo Thanks Sir! Quote time does not respect what is done without it https://tradisign.blogspot.com https://www.instagram.com/tradisign/
Members billybopp Posted November 12, 2020 Members Report Posted November 12, 2020 13 hours ago, paloma said: better than USMC one? I like Fiebings Pro Dye. USMC is a royal pain to use. Yes, it is a very deep black, but that is because it has an excess of pigment that you need to buff until your arm just about falls off. Then you buff some more and still may not remove enough pigment to keep it from bleeding. - Bill Quote
Members paloma Posted November 12, 2020 Author Members Report Posted November 12, 2020 2 minutes ago, billybopp said: I like Fiebings Pro Dye. USMC is a royal pain to use. Yes, it is a very deep black, but that is because it has an excess of pigment that you need to buff until your arm just about falls off. Then you buff some more and still may not remove enough pigment to keep it from bleeding. - Bill thank you for the advice of the procedure! Quote time does not respect what is done without it https://tradisign.blogspot.com https://www.instagram.com/tradisign/
