3M packing tape with filaments.  This stuff sticks and leather will not stretch. Have never tried applying to wet leather.  Once stuck, don't know I would dunk in water, but I use water spray to case,.and no problems with the tape.  Only downside is when pulled off, it will raise any loose fibers your leather may have.
Hope this helps
Terry
  • 1 year later...
There are a few ways to stretch your leather belt that you can try. Method 1 - Add more weight. Method 2: Create 1 more hole. Method #3: Soak in warm water. Method 4: isopropyl alcohol.Method 5: Stretch the leather with heat. Method 6: Place in the freezer. Method 7: Use leather stretching products
  • 4 weeks later...
There are several ways to prevent leather from stretching, and it ultimately depends on the type of leather you have.
Here are some general tips:
1. Choose a high-quality leather: Good quality leather is less likely to stretch than lower quality options.
2. Avoid getting your leather wet: Leather can stretch when it gets wet, so try not to expose it to water or moisture as much as possible.
3. Store your leather properly: Make sure that you store your leather items in a cool, dry place where they won't be exposed to humidity or extreme temperatures.
4. Use a conditioner: Using a conditioner on your leather periodically can help keep it hydrated and prevent excessive stretching.
5. Don't overuse or overload your leather items: Be mindful of how often and how heavily you use certain items made of leather (such as bags or shoes), as this can cause them to stretch out more quickly.
6. Get the right fit initially: When purchasing any item made of genuine leather such as jackets, pants or shoes make sure that they fit perfectly before buying them because if there is too much room left for extra space then there are chances that the material will get stretched with time due to consistent usage by an individual. By following these tips, you should be able to keep your favorite pieces of genuine-leather looking great for years without worrying about stretching issues!
Edited by Northmount
Removed spam link
