On 12/26/2020 at 8:29 PM, JJN said:
Nylon will stretch where polyester will not.
Poly. thread does stretch, it just that Nylon thread stretches more than Poly.
like ( DoninReno ) saying, the general 'rule of thumb' is that Poly.thread tends to be more UV resistant and hold dye color better when getting a beating by UV . Nylon is better for holding up for abrasion and a little higher tensile strength over Poly.
Nylon and Poly. thread both start melt right around the same Temp. , When burning each they also smell totally different . When melting thread tails,  the Nylon thread melt a lot nicer than Poly thread . I like the way Nylon thread tails makes a nice little puddle. Poly. thread tends to just Flame-on pretty intense and quick .
You also notice when hot knifing/cutting Nylon thread weave of webbing's and nylon fabrics, that it's a lot cleaner/nicer melt with Nylon.
  • 3 weeks later...
Thank you for all the guidance and help!!!B)
  • 3 years later...
13 hours ago, Synicsel said:
The stiffness and softness you're experiencing can be due to their individual properties. Bonded Nylon tends to be softer and more pliable, which can make it prone to fraying. Bonded Polyester, on the other hand, is usually stiffer and more durable.
Nylon is structurally stronger and more abrasive resistant than Poly . Poly is more UV resistant than Nylon .  Both Nylon and Poly have there versions of ' satin soft ' threads.
