Members sandmanred Posted December 30, 2020 Members Report Posted December 30, 2020 Can anyone tell me the maximum needle size, max stitch length and max clearance under the presser foot of a 111w103? I have a chance to get one and I'm having trouble finding specifics on this model. Quote Have Consew 255RB-3, Pfaff 545 H4, Chandler 217, Pfaff 138 and Merrow 60W. Had a Singer 132K6, Singer 78-3 Consew 28, Consew 18, Singer 31-15 and regret selling each and every one of them
Moderator Wizcrafts Posted December 30, 2020 Moderator Report Posted December 30, 2020 I had one until last spring. It can take a #23 needle if you want to use #138 thread. But, I found it to be more at home with #69 thread and a #18 needle. The most I used in it was #92 bonded thread, with a #19 or #20 needle.The maximum thickness is 5/16 inch on that model. But, it should be soft to medium temper material, like denim or chap/garment leather. Be careful turning the stitch length knob on the balance wheel. The top rear shaft has threads machined into it and they get brittle and break after 75 years of service. When the threads are gone you will have trouble changing the stitch length. The maximum stitch length is about 4.5 to 5 to the inch on that model. But, it can be tweaked for a bit longer. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members sandmanred Posted December 30, 2020 Author Members Report Posted December 30, 2020 Great, thanks for the information! I think I'll keep shopping, I'd like to run a bit bigger needle if needed. Quote Have Consew 255RB-3, Pfaff 545 H4, Chandler 217, Pfaff 138 and Merrow 60W. Had a Singer 132K6, Singer 78-3 Consew 28, Consew 18, Singer 31-15 and regret selling each and every one of them
Members ryano Posted December 30, 2020 Members Report Posted December 30, 2020 1 minute ago, sandmanred said: Great, thanks for the information! I think I'll keep shopping, I'd like to run a bit bigger needle if needed What kind of machine are you looking for? Quote
Members sandmanred Posted December 30, 2020 Author Members Report Posted December 30, 2020 Lock stitch, compound feed, at least 3/8 under the presser foot, needle size up to 25 or 200 metric, stitch length up to 7mm or 3.5/inch, manual oiling and common so I can easily get parts. If it's rotary hook it'd be nice to have a clutch. Large bobbin would be nice too but not necessary. Head only is okay but would prefer it in some kind of table with motor. Quote Have Consew 255RB-3, Pfaff 545 H4, Chandler 217, Pfaff 138 and Merrow 60W. Had a Singer 132K6, Singer 78-3 Consew 28, Consew 18, Singer 31-15 and regret selling each and every one of them
Moderator Wizcrafts Posted December 30, 2020 Moderator Report Posted December 30, 2020 1 hour ago, sandmanred said: Lock stitch, compound feed, at least 3/8 under the presser foot, needle size up to 25 or 200 metric, stitch length up to 7mm or 3.5/inch, manual oiling and common so I can easily get parts. If it's rotary hook it'd be nice to have a clutch. Large bobbin would be nice too but not necessary. Head only is okay but would prefer it in some kind of table with motor. You have just described the Consew 206RB-5. Juki has several walking foot machines meeting your wish list, including the DNU-1541 and LU-1508NH. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
