Jakeman711 Report post Posted January 5, 2021 I hope all of you had a good Holiday Season. I recently started sewing and found out that I needed a larger sewing machine. I am sewing Cordura and the Heavy Duty Singer 4411 I bought is coming up a bit short. I bought a Singer 111w103 and have been reading on this forum about the machine and machines like it. I have found that my machine doesn't have the clutch on the timing gear that new generations of the 111w have. I was wondering if I could put the clutched gear into my machine to protect it from damage? If it is possible is it worth it? I look forward to reading your replies. -Jacob Quote Share this post Link to post Share on other sites
nylonRigging Report post Posted January 5, 2021 That machine has been sewing for how many years without having it ? ... So (IMHO ) you just over thinking it . Just Sew with it . It probably has no reverse lever, still it is a really good all-around machine to have in your stable. Easy to work on, and easy find and inexpensive parts also . . Quote Share this post Link to post Share on other sites
sandmanred Report post Posted January 6, 2021 I've got an old Singer 132K6 a rotary hook with no safety clutch. On mine there's a group of 3 set screws that fasten the hook to the shaft that drives it. It seems this is 'clutch' on these simpler machines as it was badly out of time when I got it and this was the only adjustment I had to make to get it sewing again. A modern clutch with a detent just makes the re-timing after a jam as simple as re-setting the clutch to the detent point. I have to remove a cover over the hook area, loosen the 3 set screws, re-time and re-assemble. It takes 5-10 minutes instead of a few seconds. Quote Share this post Link to post Share on other sites
Jakeman711 Report post Posted January 19, 2021 Thank you for your replies. I really to appreciate it. This machine does not have reverse, but that isn’t a big deal for me. I really do enjoy sewing with it. I put a servo motor on it with a smaller pulley. Nothing like sewing with a piece of history. Every time someone comes over and see’s the 111, they always comment on it. Hope all is well. -Jacob Quote Share this post Link to post Share on other sites
