Hello,
   Whenever I check a machine on google the info is always this site. I'm not specifically looking to do leatherwork, although it might be pressed into that.  I would be doing canvas projects for my antique wood sailboat. I have done a stint in a sail loft and can work with a clutch machine.  Locally there is an Adler 67-22L listed on CL.  The ad says needs a rebuild and $300 for the hard only, but it also says the shop is closing and all inventory must go.  I can't find any info on the 22L subgroup. The ad says walking foot but doesn't say compound feed.
Does anyone know anything about the Adler 67-22L?
I've got a little Neechi that will do my current projects, but am on the lookout for something with a bigger throat distance.
Thanks,
Chris
I can’t answer the question about that particular model, but in general I wouldn’t suggest a worn out machine as a first industrial, especially at that price.   Adler parts are not cheap, if available at all for an older model.   In a production shop if a machine is set on the shelf for being worn out it’s not a simple fix, or they would have already fixed it.
There are plenty of flat bedtripple feed machines in much better shape for that price.
Most important - check the condition of the timing belt - changing it is a pain!
It's a four hour round trip to the machine.  I wouldn't be willing to pay that price, but I'm doubting anyone else would either.  If "everything has to go" I'm thinking when the time comes it might be cheap.  If he offered a good price I'll go check it for lash etc.  I just figured I would try and find out about the model and parts availability/prices first.  I could swallow some lost time changing the belt if it's a $40 belt.  If other parts are extortionately priced or unavailable...
Thanks for any advise.
Do you have pictures of that machine? Not all Class 67 where triple feed ("walking foot") machines they came as needle feed + drop feed and roller foot machines as well. So before you make the trip some pictures may help to ID the machine.
The guy isn't too responsive. I ask specific questions and it's like texting a teenager; his replies don't directly answer my questions.  I was hoping one of you guys might know what a 22L is and perhaps be ready when he has to vacate the premises.
I once worked in a sail loft in Key West and took the machine heads to Miami for tune-ups before Race Week, there was a long arm Adler that I remember as being a Clydsdale amoung the herd.
The fellow is going to email me a picture of it. When it comes I'll try and post it here.  Maybe someone will be able to tell its age.  I've noticed some have a knob vs lever for controls.
Thanks
I haven't heard back with a photo.   Are Singers a better option for affordable parts than Adlers or Pfaffs, particularly for someone that doesn't have the experience to judge wear ?
Well, old machines are old machines no matter the brand but a lot of the more modern machines are rather based on Singer models than on other brands. So the availability and the price tag of certain parts is better for Singer based machines. Of course you do not get everything new but looking over the fence a little bit shows a wide range of interchangeable parts on other brands based on Singer machines - especially in the "upholstery class". But don´t get me wrong, you of course can get Adler and Pfaff parts but the older the model the harder it is to find certain spare parts. When you read restoration threads here you figure that f.i. Pfaff has changed several parts even on the same model over the years. I figured that's too when I looked for screws a while ago.
I´m not bashing Pfaff or Adler - excellent machine, no doubt. But I´m using Singer machines only and thats for a reason. When you do not need the latest technical craze then old Singer models are a good choice. For most of my machines I at least can tell you one or two other brands where I can get interchangeable parts from (either new or used). Especially after market Singer hooks are extremely cheap nowadays. But being "Singer crazy" is just my philosophy but that does not mean that this is everybody else's "best choice" too. Especially when the market for used machines is small you often have to buy what crosses your way. At the end you are the one who has to put the money on the table.
Thanks for the info Constabulary.  The only machine in my limited knowledge copied singer is consoe.  Watching craigslist I've seen a couple machines come up free, get them out of the basement.  One was a singer 188k-1,  the other a Singer 251.  I would've needed to change the motors to low speed I expect, but both were gone before I got there.
I don't have high hopes for the economy so I bide my time and keep watching CraigsList.   Walking foot would of course be good when dealing with large fabric like sails etc so the machine can drag it across the table while you pay attention to guiding.  (I don't even hope for walking foot zig-zag) And for the same reason reverse would be good because of the fabric hanging across table I expect would make it a problem to push the fabric by hand and then stitch over.   But I think I could make do with a drop feed machine if I had to and it had the 11" table width (I know a long arm machine would be too expensive).
I'm very impressed with this Neechi BU Mira.  What beautiful piece of design and workmanship.  Too bad there isn't a larger version.
