Members chiefjason Posted February 2, 2021 Members Report Posted February 2, 2021 OK, I found this mold a while back. Put it up as a listing on my etsy page. Just sold a holster for it. Now I'm at a loss for where I found it. So I'm coming here to see if anyone has seen one. Called Boise Foundry and no luck. And that's where I thought it was. Checked Holstersmith and Bluegunstore. No luck. My email to Duncan's bounced back as undeliverable. Next option, seems this is close in size to a Colt Python. Any experience with that? It's not a tightly molded holster so close should work. But it does have a security strap so it needs to be real close. Quote
Members Brooks125 Posted February 3, 2021 Members Report Posted February 3, 2021 I've made a few for Dan Wesson, but I always need the gun. The front cylinder release is unique. If it's a loose design, the Python "Large Magnum" from Bunkhouse may work also, but I'd look up the cylinder diameter before you do. Quote "Be polite. Be professional..."
Members chiefjason Posted February 8, 2021 Author Members Report Posted February 8, 2021 On 2/2/2021 at 8:45 PM, Brooks125 said: I've made a few for Dan Wesson, but I always need the gun. The front cylinder release is unique. If it's a loose design, the Python "Large Magnum" from Bunkhouse may work also, but I'd look up the cylinder diameter before you do. I'm going with the Colt Python. Cylinder is just a hair wider than the 715. I do no molding on the release side of the cylinder. It's kind of a western style holster with a strap, so no real friction retention at play. But I removed the listing until I can verify this works. Quote
