Members Josacraw Posted February 7, 2021 Members Report Posted February 7, 2021 I purchased this pfaff 438 that has an added on cloth puller. It is not the pfaff puller but some type of after market. Can anyone tell me what it is/who made it? Quote
Members Gregg From Keystone Sewing Posted February 7, 2021 Members Report Posted February 7, 2021 Michael Joseph, or MJ. They were really good. Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Members Josacraw Posted February 8, 2021 Author Members Report Posted February 8, 2021 Thanks Gregg! Is there any chance that a manual exists for these? I looked em up on the old googs and couldn't find a thing. The puller is very straight forward, no pun intended, and has no reverse function since it is driven off the flywheel. In sail sewing there's not a lot of need to use reverse to lock a stitch but it does come up. So it would be nice to be able to lift the puller while leaving the foot down. Not sure if anyone has seen a modification to do this. And lastly to change stitch length I believe I would adjust the center screw on the flywheel to make the pitman arm more eccentric? As always thanks. What you guys know could fill a warehouse. Quote
Members Gregg From Keystone Sewing Posted February 12, 2021 Members Report Posted February 12, 2021 On 2/7/2021 at 7:27 PM, Josacraw said: The puller is very straight forward, no pun intended, and has no reverse function since it is driven off the flywheel. In sail sewing there's not a lot of need to use reverse to lock a stitch but it does come up. So it would be nice to be able to lift the puller while leaving the foot down. Not sure if anyone has seen a modification to do this. ld adjust the center screw on the flywheel to make the pitman arm more eccentric? As always thanks. What you guys know could fill a warehouse. Stitch length, yes you got it. The way pullers work in almost every case is that they are one way directional. You can either lift the puller manually and then reverse if the machine can do that. There are pullers from the factory like Racing that allow you to hook up either electronic solenoid or pneumatic cylinder to automate the process. Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Members Gregg From Keystone Sewing Posted February 13, 2021 Members Report Posted February 13, 2021 (edited) YouTube Video Racing Puller Example See attached, this is a good example of the Racing puller I'm speaking of. Edited February 14, 2021 by Wizcrafts I fixed the URL Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Moderator Wizcrafts Posted February 14, 2021 Moderator Report Posted February 14, 2021 22 hours ago, Gregg From Keystone Sewing said: YouTube Video Racing Puller Example See attached, this is a good example of the Racing puller I'm speaking of. This link leads to a 404 Not Found error: Oops, something went wrong. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Gregg From Keystone Sewing Posted February 14, 2021 Members Report Posted February 14, 2021 14 hours ago, Wizcrafts said: This link leads to a 404 Not Found error: Oops, something went wrong. I tested it again on my windows PC. Should take you to YouTube. Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Members Gregg From Keystone Sewing Posted February 14, 2021 Members Report Posted February 14, 2021 20 hours ago, Gregg From Keystone Sewing said: Updated YouTube Video Link Try This One Thanks Wiz! See attached, this is a good example of the Racing puller I'm speaking of. Fixed. Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Moderator Wizcrafts Posted February 14, 2021 Moderator Report Posted February 14, 2021 1 hour ago, Gregg From Keystone Sewing said: Fixed. Thanks Gregg. I was wondering what a "racing puller" could be until I watched the short video. They confused "racing" with "raising!" The puller raises up to allow back-tacking. Then, it's off to the "races!" Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Oharjo Posted June 4 Members Report Posted June 4 Restarting this thread here... I've got one of these pullers on a Singer 107w3, and I need to replace the rubber roller (it's disintigrated and gone, but the metal bearing at the center is still on the shaft) - and I've got no idea how to source one of these. The roller's shaft is 7/16" and looks like it was 1 1/8" wide with something smaller than a 2" diameter. Any ideas where to look? The sewing supply companies with rollers I can find online don't list the dimensions of their rollers and can't tell me what the dimensions are when I call them... Quote
Members Dave9111 Posted June 6 Members Report Posted June 6 Id look at Mcmaster Carr and see what they have. You might also be able to use a urethane roller. Once you get a new roller, dont leave it under pressure when your not using the machine. Some urethane, I believe, can be machined. Rubber can be ground or sanded. I had a rubber puller roller that had a flatspot. I put the roller in a drill press then used a sander to make it round. Ive heard of rubber being turned in a lathe after freezing it. But Ive never done that. Quote
Members Oharjo Posted Monday at 05:28 PM Members Report Posted Monday at 05:28 PM Thanks Dave9111! Quote
